04-25-2016, 17:31 | #1 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 735781 Status: Offline Thanks Meter: 18 | Sm-G920F drk failed i have received s6 with bootloop problem. i have flash it two different firmware from sammobile. but after flash it goes to recovery and giving drp failed error. have any idea?? Sent from my SM-G900 using Tapatalk |
04-25-2016, 18:00 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. To fix corrupted DRK, please do the next: 1. Root the phone, or write a custom kernel. You can try to use CF Auto Root for this purpose. 2. Perform "DRK Fix" operation 3. Reflash the phone |
06-11-2016, 11:33 | #6 (permalink) |
Member: 735781 Status: Offline Thanks Meter: 18 | after root set working.perfect. but when.i restore the mobile. its goes.to again recovery mode. and stuck there.... is there any solution... Sent from my HUAWEI MT1-T00 using Tapatalk |
06-11-2016, 12:49 | #10 (permalink) |
Member: 735781 Status: Offline Thanks Meter: 18 | sir first i flash mobile with 6.0 after flash mobile stuck on recovery. then i root it. n set start normally. after startup i fix drk. when i restore my mobile for checking drk its stuck again dm verification.failed. Sent from my HUAWEI MT1-T00 using Tapatalk |
06-11-2016, 16:17 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | At first You need to remove FRP lock via "Reset FRP/Reactivation/EE" operation. Then proceed with steps from previous post. |
