04-20-2016, 18:41 | #1 (permalink) |
Freak Poster Join Date: May 2014
Member: 2188261 Status: Offline Thanks Meter: 13 | Sm-g925t frp lock error [Solved] ----------------------------------------------------------------------------------- To connect SM-G925T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G925T To put SM-G925T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock.. Operation was failed! Performed by 2.2.4 software version LOG BELOW https://drive.google.com/file/d/0B-W...ew?usp=sharing Last edited by Octopus box; 04-21-2016 at 10:54. |
04-20-2016, 19:07 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. Try to write "SBOOT_G925T_OJ7" SBoot file from the Support Area as a firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
04-20-2016, 19:44 | #3 (permalink) | |
Member: 2188261 Status: Offline Thanks Meter: 13 | Quote:
