02-09-2017, 11:37 | #1 (permalink) |
No Life Poster Join Date: Apr 2016
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | g530f emergency call 1st tell how write cert on g530f? i try with direct cable ,without battry termanil block 2nd with urt cable 3rd urt cable with block termnal but with URT its not connecting how and why?? Platform: Samsung Android Selected port: COM3 Selected model: SM-G530F Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Select Certificate2... Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Phone was not found Writing Certificate failed Performed by 2.4.7 Software version. after i write cert with another box , but still emergency call ??? |
02-09-2017, 11:56 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Hello. To connect the phone via UART, You need to block highlighted pin with a tape/paper and use Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. Also, please manually select COM port of the box in Software. |
02-09-2017, 12:04 | #3 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | but as i say i write cert another box but still emergency call sometime it take signals but still emergency again ok i,ll again reset msl . EFS sec and write again |
02-09-2017, 12:13 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Such issue can occur if IMEI of Cert file is black listed. Also You can try to write a QCN from another, correctly working SM-G530F (remember to make backup of phone's original QCN). |
02-09-2017, 13:05 | #6 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | still same o connect GT-I9190 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM75 Selected model: SM-G530F Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Phone was not found Writing Certificate failed Performed by 2.4.7 Software version. |
02-09-2017, 14:17 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Try to reinstall FTDI drivers (http://octoplusbox.com/files/drivers...rs_2.08.24.zip). Try to use another Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. |
02-09-2017, 15:39 | #8 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | Platform: Samsung Android Selected port: COM75 Selected model: SM-G530F Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... |
02-09-2017, 15:44 | #9 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 ----------------------------------------------------------------------------------- To connect SM-G530F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM75 Selected model: SM-G530F Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Phone was not found Writing Certificate failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G530F Selected file: C:\Users\DAVED\Downloads\Cert-SM-G530F_355965060136244_R123456789S.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Phone was not found Writing Certificate failed Performed by 2.4.7 Software version. |
02-09-2017, 15:58 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | If You've blocked necessary battery pin, re-installed FTDI drivers and tried to use another Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection, but problem remains - try to use another box as UART interface. |
02-10-2017, 06:30 | #11 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | ok write cert with another, but its still after a few minuts emergency call, i write it another OK qcn , so after that it work for sometime but again still emergency call the cert is from your support , and the whole net searched but found just your cert file, not have another cert file in case now i manage another set so how can i read kindly do something |
