04-16-2015, 12:24 | #1 (permalink) |
Major Poster Join Date: Jan 2015
Member: 2323190 Status: Offline Thanks Meter: 1 | Unlock G800F S5 Mini I tryed to unlock it with the "unlock" button. All is good but it doesn't work... so I would write cert but I don't know where I can download it. Someone has some ideas? Thanks |
The Following User Says Thank You to mirko112 For This Useful Post: |
04-16-2015, 12:30 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Hello. All Certificates files, which we have, are present in the Support Area (press "Go to Support" button at "Support & Options" tab in the Software) in the folder "Samsung/FOR UNLOCK ANDREPAIR/Certificates/". Also, look here: http://forum.gsmhosting.com/vbb/f684...-list-1320364/. |
04-16-2015, 13:53 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | SM-G800F is Exynos CPU-based device, not Qualcomm CPU-based, there is no Wipe Security/EFS operation. Just write IMEI Certificate. And post here full Software log. Also, if You want only to unlock the phone, make Unlock operation, no need to write IMEI Certificate. |
04-16-2015, 14:06 | #5 (permalink) |
Member: 2323190 Status: Offline Thanks Meter: 1 | I tryed only the Unlock but however the 3g doesn't work Platform: Samsung Android Selected port: COM7 Selected model: SM-G800F Selected file: C:\Users\Centrino\Downloads\cert-sm-g800y_354481065051157_r58f91kvvk.cert Detected phone model: SM-G800F Firmware compiled date: Mon Dec 1 15:49:07 KST 2014 PDA version: G800FXXU1ANL1 CSC version: G800FITV1AOC1 SW version: G800FXXU1AOC2 Phone IMEI: 353923060317886 Phone SN: R58F90Y89TP Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G800F-Unknown16-04-2015_14-07-44-.asec file Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM11 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Certificate has been written successfully Please, restart the phone to apply changes |
04-16-2015, 14:19 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Select correct Network Mode, then try to select Network manually. |
04-16-2015, 17:24 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Try to make Factory data reset and wipe cache partition and re-flash the phone with other firmwares, no other solution. |
04-16-2015, 17:47 | #9 (permalink) | |
No Life Poster Join Date: Aug 2006
Member: 331337 Status: Offline Thanks Meter: 72 | if we write imei certificate would that change the original imei? if we write imei certificate on g800f phone , would that change the original imei to new one from security? I need imie repaire for g800f . please help. thanks in advance. Quote:
04-16-2015, 18:01 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | After "Write Cert" operation phone will have IMEI of the Cert file. |
04-17-2015, 13:27 | #14 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Quote:
