04-14-2015, 13:43 | #1 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2348242 Status: Offline Thanks Meter: 0 | SM-N910F after IMEI repair NO NETWORK problem with italian operator after IMEI repair (replace with certificate on you site). procedure all ok, imei changed, re-flash with same FW to origin phone: can't register network any ideas ? |
04-14-2015, 13:54 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Write QCNs from the Support Area, insert SIM card and try to find and select network manually. If the network is still disabled, most likely, IMEI from the IMEI certificate file, that You have written, is in the "black" list of your network operator - try to write other IMEI Certificates. |
