04-16-2015, 19:26 | #1 (permalink) |
No Life Poster Join Date: Dec 2014 Location: u.a.e
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | sm-t211 and reflash phone by octoplusbox problem imei is 001068000000006 ican't repair imei Platform: Samsung Android Selected port: COM12 Selected model: SM-T211 Detected phone model: SM-T211 Firmware compiled date: Thu Nov 28 17:42:45 KST 2013 PDA version: T211XXAMK7 CSC version: T211OJVAMK1 SW version: T211XXAMGM Phone IMEI: 001068000000006 Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Deactivating MSL... Write IMEI failed plese help |
The Following User Says Thank You to mojahed.br For This Useful Post: |
04-16-2015, 19:37 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Install the latest Software version (Software), write 4.4.2 firmware, make Factory data reset and perform the Repair IMEI operation once again. Post here full Software log with all of your actions. |
04-17-2015, 01:15 | #3 (permalink) |
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | Thank you very much for reply you are a best team good support and answer to help us I will try and post here full software after download 4.4.2 |
04-20-2015, 22:08 | #5 (permalink) |
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | root done but same problem Platform: Samsung Android Selected port: COM12 Selected model: SM-T211 Detected phone model: SM-T211 Firmware compiled date: Mon Sep 8 17:16:42 KST 2014 PDA version: T211XXBNI2 CSC version: T211OJVBNI2 SW version: T211XXBNI2 Phone IMEI: 001068000000006 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Deactivating MSL... Write IMEI failed |
04-29-2015, 12:58 | #6 (permalink) | |
Freak Poster Join Date: May 2010
Member: 1306306 Status: Offline Sonork: 240888 Thanks Meter: 36 | Quote:
04-29-2015, 13:03 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Most likely, EFS is damaged in your device. Unfortunately, Repair EFS is currently not supported for this device. Try to read out EFS from another device with correct IMEI and write it into your phone, then make Repair IMEI. |
04-29-2015, 13:14 | #8 (permalink) |
Member: 1306306 Status: Offline Sonork: 240888 Thanks Meter: 36 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.3To connect SM-T211 ----------------------------------------------------------------------------------- phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: T211_Ready_to_root.oct Please put the phone into Download Mode and connect USB cable. To put SM-T211 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM90 Selected model: SM-T211 Detected phone model: SM-T211 Firmware compiled date: Thu Mar 6 13:24:29 KST 2014 PDA version: T211XXANC1 CSC version: T211OLBANC1 SW version: T211XXANC1 Phone IMEI: 001068000000006 Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Deactivating MSL... Write IMEI failed |
04-29-2015, 13:18 | #9 (permalink) | |
BR. | |
04-29-2015, 13:23 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Unfortunately, currently we have no EFS backup for this device. We have prepared and sent You test Software version to PM. Read out backups of EFS and Security from your device, upload they somewhere and post here links, we will research, where can be the problem exactly. |
04-29-2015, 14:02 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have research backups. Yes, EFS and Security are damaged in your device. You should find and write EFS from another SM-T211 with correct IMEI, write it into your phone, then make Repair IMEI. |
