04-20-2016, 08:25 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 775567 Status: Offline Sonork: tybsky Thanks Meter: 59 | smj700h frp error _________________________________________________ Please put the phone into Download Mode and connect USB cable. To put SM-J700H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing Firmware Failed Performed by 2.2.4 software version what's the problem |
04-20-2016, 11:28 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. In order to remove FRP lock, please perform "Reset FRP/Reactivation/EE" operation. Post here the result. Last edited by Octopus box; 04-20-2016 at 13:55. |
04-20-2016, 11:48 | #3 (permalink) |
Member: 775567 Status: Offline Sonork: tybsky Thanks Meter: 59 | Platform: Samsung Android Selected port: COM1 Selected model: SM-J700H Connecting to server... Connecting to server...Ok! Checking resource files... Downloading resources... All necessary resource files have been downloaded successfully. Please put the phone into Download Mode and connect USB cable. To put SM-J700H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Recovery section... Recovery section has been written successfully. Writing Firmware Failed Performed by 2.2.4 software version |
04-20-2016, 12:18 | #5 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: Pakistan Islamabad
Member: 299534 Status: Offline Sonork: 100.1651558 Thanks Meter: 36 | Quote:
dear u need to press on FRP Lock | |
04-20-2016, 13:35 | #6 (permalink) |
Member: 775567 Status: Offline Sonork: tybsky Thanks Meter: 59 | Platform: Samsung Android Selected port: COM1 Selected model: SM-J700H To put SM-J700H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock.. Operation was failed! Performed by 2.2.4 software version and here is Flashing log : Selected firmware file: J700HXXU1AOK5_J700HOJV1AOK6_TUN_Android_5.1.1_2.oc t Please put the phone into Download Mode and connect USB cable. To put SM-J700H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing Firmware Failed Performed by 2.2.4 software version |
04-20-2016, 13:56 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to make Factory Reset and Wipe cache partition from Recovery Mode, then repeat "Reset FRP/Reactivation/EE" operation. Post here the result. |
04-21-2016, 11:54 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. We will check what causes the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
