01-01-2014, 02:17 | #1 (permalink) |
Crazy Poster Join Date: Jun 2013
Member: 1957672 Status: Offline Thanks Meter: 11 | Successful Unlock SC-04E Welcome to Octoplus/Octopus Box Samsung software version 1.4.3 ----------------------------------------------------------------------------------- To connect SC-04E phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: SC04EOMUAMDI_SC04EDCMAMDI_SC04EOMUAMDI_HOME.oct Please switch your phone to the download mode and connect it to a PC. To put SC-04E phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing SBL2 section... SBL2 section has been written successfully. Writing SBL3 section... SBL3 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-04E Mode: Emergency Unlock for SC-04E phone in emergency mode can’t be done ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM94 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW Version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM95 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 23 2013 Firmware released time: 15:11:45 Phone IMEI: 356778-05-802278-2 SW Version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM95 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 23 2013 Firmware released time: 15:11:45 Phone IMEI: 356778-05-802278-2 SW Version: M9615A-CEFWTAZM-4.0.17062 Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Selected firmware file: SC04EOMUAMI1_SC04EDCMAMI1 _SC04EOMUAMI1_HOME.oct Please switch your phone to the download mode and connect it to a PC. To put SC-04E phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing SBL2 section... SBL2 section has been written successfully. Writing SBL3 section... SBL3 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Note : in order to unlock this u need rewrite your phone to the lower version after that make unlock (phone have no sound but dont worry) just reflash your device to the last version enjoy your phone unlocked |
The Following 3 Users Say Thank You to l.panha For This Useful Post: |
