04-23-2016, 12:40 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Sylhet Bangladesh
Member: 2145140 Status: Offline Sonork: 100.1650938 Thanks Meter: 90 | Successfully Unlocked SM-G900F ----------------------------------------------------------------------------------- To connect SM-G360H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-G900F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM44 Selected model: SM-G900F Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM164 Mode: Normal Phone model: SM-G900F Firmware compiled date: Jun 03 2015 Firmware compiled time: 04:00:00 Firmware released date: Oct 5 2015 Firmware released time: 11:21:55 Phone IMEI: 359660-06-654130-9 SW version: MPSS.DI.2.0.1.c2.7-00015-M8974AAAAANRZM-1 Performed by 2.2.5 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM164 Selected model: SM-G900F Reading info... Mode: Normal Firmware compiled date: Jun 03 2015 Firmware compiled time: 04:00:00 Firmware released date: Oct 5 2015 Firmware released time: 11:21:55 SW Version: MPSS.DI.2.0.1.c2.7-00015-M8974AAAAANRZM-1 ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900F Firmware compiled date: Mon Oct 5 16:14:38 KST 2015 PDA version: G900FXXU1BOJ1 CSC version: G900FOJV1BOF1 SW version: G900FXXU1BOJ1 Phone SN: R58GB0WNG2Y Android version: 5.0 (LRX21T) Country: KSA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltexx Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.5 software version |
The Following User Says Thank You to Anamul.2014 For This Useful Post: |
