10-04-2016, 14:42 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Hello. Such problem can occur if root method, which You've used is not compatible with the phone (phone firmware). Reflash the phone, then try to root it with another tool/exploit. |
10-11-2016, 09:27 | #6 (permalink) | |
No Life Poster Join Date: Jan 2007
Member: 441775 Status: Offline Thanks Meter: 22 | Quote:
<OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:1/004> Added!! <ID:0/009> Odin engine v(ID:3.1100).. <ID:1/004> Odin engine v(ID:3.1100).. <ID:1/004> File analysis.. <ID:0/009> File analysis.. <ID:1/004> SetupConnection.. <ID:0/009> SetupConnection.. <ID:1/004> Initialzation.. <ID:1/004> Get PIT for mapping.. <ID:1/004> Firmware update start.. <ID:1/004> SingleDownload. <ID:1/004> boot.img <ID:1/004> NAND Write Start!! <ID:1/004> cache.img <ID:1/004> cm.bin <ID:1/004> FAIL! <ID:1/004> <ID:1/004> Complete(Write) operation failed. | |
10-12-2016, 08:58 | #7 (permalink) |
Member: 441775 Status: Offline Thanks Meter: 22 | ultime software fail <ID:0/004> Added!! <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/004> Odin engine v(ID:3.1100).. <ID:0/004> File analysis.. <ID:0/004> SetupConnection.. <ID:0/004> Initialzation.. <ID:0/004> Get PIT for mapping.. <ID:0/004> Firmware update start.. <ID:0/004> SingleDownload. <ID:0/004> sboot.bin <ID:0/004> NAND Write Start!! <ID:0/004> cm.bin <ID:0/004> boot.img <ID:0/004> recovery.img <ID:0/004> system.img <ID:0/004> cache.img <ID:0/004> hidden.img <ID:0/004> FAIL! <ID:0/004> <ID:0/004> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1 |
10-12-2016, 09:15 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | You can try to do the next: 1. Convert firmware, which You've tried to write into *.oct format. 2. Try to write it via "Advanced Mode", without "hidden" partition (un-check hidden partition during the process). |
10-12-2016, 11:28 | #9 (permalink) | |
No Life Poster Join Date: Sep 2009
Member: 1109337 Status: Offline Thanks Meter: 197 | Quote:
