06-17-2020, 11:21 | #1 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2151795 Status: Offline Thanks Meter: 17 | T585 E: failed to mount /efs [Solved] E: failed to mount /efs I try to reflash but no succes. Someone have soluction oe EFS file to write? Thanks |
06-19-2020, 10:49 | #2 (permalink) |
Member: 2151795 Status: Offline Thanks Meter: 17 | I solved with this procedure: Flash an official firmware Flash CWM recovery Boot into Recovery Select mount and storage -> mont /system Connect your phone to PC using USB cable Open ADB command window and type the following commands adb shell mke2fs /dev/block/mmcblk0p3 mount -w -t ext4 /dev/block/mmcblk0p3 reboot Now phone boot but imei is 000000000000000 It's possible repair imei with Cert file or credits? Thanks for reaply |
The Following 2 Users Say Thank You to fabb_ved For This Useful Post: |
