Step by step... how to unlock azalis288 100% work!!!!! 1.use all philips serv.software by andy delock 2.check azalis 238 type 1(2M flash) 3.open flsh file(azalis 2m_cloned flash file) see old post 4.Set speed to 38400 5.press write flash 6.when phone is flashed press tat mode 7.go to eep section edit and selecz sector 11 8.paste this in sect. 11 and press write section 1D 07 01 E4 31 32 33 34 98 12 04 59 74 36 55 84 72 99 27 90 FF FF FF FF 00 00 00 0A FF FF FF FF FF FF FF FF 00 01 FF FF FF FF FF FF FF FF FF FF 00 02 00 00 FF FF FF FF FF FF FF FF 00 03 00 00 FF FF FF FF FF FF FF FF 00 04 00 00 0A 00 00 00 00 00 00 00 62 F2 00 30 00 FF 00 00 00 FF 00 00 00 FF 00 00 00 FF 00 00 00 FF 00 00 00 FF 00 00 00 FF 00 00 FF FF 00 00 00 FF 00 00 FF FF FF FF FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF FF FF FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF FF FF FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 9.press tat mode again 10.when phone is in tat mode press restore default section Solution work perfect and tested by my b.r. |
What abaut Azalis 288 whith flash 4M Regards |
work without flashing Press only tat mode and restore sect. thats all |
see old post all philips service software |
Hi all :) I have a "little big" problem with aza 288 and Delok - phone enters tat mode, but software still saying "Waiting for ignition" ... And when I tryed to flash him - after loading boot phone answers FF 00 FF 0D 00 48 1C 60 30 81 and freezez ... Any help ? |
When you will flash the phone you dont need push tat mode buton. Only load file to program,set speed to 38400 and put write flash. Thats all |
hi all i need this flash plz i need help thx :rolleyes: |
Today I found this:phone charging normal but can not charge the batery with this flash!!!!! I put back the original flash,all normal but locked!! What is the solution for this problem??? |
how about putting in old flash get codes using reader put original flash back type in codes ... |
Can not read codes!!!!! |
Darksir, you should be able to, as only the new firmware prevents reading of protected area. Or maybe the Old flash is still too new. |
Hi. I need this delock soft. Who can help me? Thanks for attention. |
