08-16-2012, 15:01 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Rio de Janeiro - Brasil
Member: 797068 Status: Offline Thanks Meter: 75 | E10A repair imei error [Solved] Welcome to Octopus Suite version 1.1.0 -------------------------------------------------------------------------------- Connecting to server...OK Username: rochater Authorizing...OK Checking balance...OK Your balance: 8 credits. Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa Authorizing...OK Checking operation...OK Your balance: 0 credits. To Repair IMEI for E10a you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10a Firmware version: 1.2.A.1.174 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...Failed! Error code: PQR1237B23 -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa Authorizing...OK Checking operation...OK Your balance: 0 credits. To Repair IMEI for E10a you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10a Firmware version: 1.2.A.1.174 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...Failed! Unable to reconnect device. Please, close all Applications using ADB, reconnect the phone and try again. Please, close all Applications using ADB, reconnect the phone and try again. -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa Authorizing...OK Checking operation...OK Your balance: 0 credits. To Repair IMEI for E10a you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10a Firmware version: 1.2.A.1.174 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is already rooted. Initializing flash...Failed! Error code: PQR1237B23 -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa Authorizing...OK Checking operation...OK Your balance: 0 credits. To Repair IMEI for E10a you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10a Firmware version: 1.2.A.1.174 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...Failed! Unable to reconnect device. Please, close all Applications using ADB, reconnect the phone and try again. Please, close all Applications using ADB, reconnect the phone and try again. -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa Authorizing...OK Checking operation...OK Your balance: 0 credits. To Repair IMEI for E10a you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10a Firmware version: 1.2.A.1.174 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is already rooted. Initializing flash...Failed! Error code: PQR1237B23 -------------------------------------------------------------------------------- Connecting to server...OK Username: rochater Authorizing...OK Checking balance...OK Your balance: 8 credits. Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa Authorizing...OK Checking operation...OK Your balance: 0 credits. To Repair IMEI for E10a you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10a Firmware version: 1.2.A.1.174 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...Failed! Error code: PQR1237B23 -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Octopus smart card is present. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10a Firmware version: 1.2.A.1.174 Kernel version: 2.6.29 -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa Authorizing...OK Checking operation...OK Your balance: 0 credits. To Repair IMEI for E10a you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10a Firmware version: 1.2.A.1.174 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...Failed! Error code: PQR1237B23 -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa Authorizing...OK Checking operation...OK Your balance: 0 credits. To Repair IMEI for E10a you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10a Firmware version: 1.2.A.1.174 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...Failed! Error code: PQR1237B23 Last edited by Octopus box; 08-21-2012 at 06:55. |
08-17-2012, 13:31 | #4 (permalink) |
Member: 797068 Status: Offline Thanks Meter: 75 | I same erro in the new version!!!! Welcome to Octopus Suite version 1.1.0 -------------------------------------------------------------------------------- Connecting to server...OK Username: rochater Authorizing...OK Checking balance...OK Your balance: 8 credits. Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa Authorizing...OK Checking operation...OK Your balance: 0 credits. To Repair IMEI for E10a you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10a Firmware version: 1.2.A.1.174 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...Failed! Error code: PQR1237B23 |
08-20-2012, 11:38 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please re-flash the phone with the firmware https://www.boot-loader.com/app/webr...T_UA_WORLD.oct from the support area and repeat operation again. |
08-20-2012, 17:33 | #6 (permalink) | |
Member: 797068 Status: Offline Thanks Meter: 75 | I'm downloading, I'll try here and then I return to tell if it worked! Quote:
I'm downloading, I'll try here and then I return to tell if it worked! | |
08-20-2012, 17:54 | #7 (permalink) |
Member: 797068 Status: Offline Thanks Meter: 75 | Thanks suporte 100% change imei!!! Welcome to Octopus Suite version 1.1.0 -------------------------------------------------------------------------------- Connecting to server...OK Username: rochater Authorizing...OK Checking balance...OK Your balance: 8 credits. Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa Authorizing...OK Checking operation...OK Your balance: 0 credits. To Repair IMEI for E10a you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Checking security...OK Reading Partition table... Could not read SBL. Maybe, NAND MPU is enabled. Disabling NAND MPU...OK Reconnecting device. Please wait...OK Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...Failed! Unable to reconnect device. Please, close all Applications using ADB, reconnect the phone and try again. Please, close all Applications using ADB, reconnect the phone and try again. -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: E10a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: SE Unlimited, Medusa Authorizing...OK Checking operation...OK Your balance: 0 credits. To Repair IMEI for E10a you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 42593930303833555042 Device status: ACTIVE Reading info... Detected model name: E10i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is already rooted. Initializing flash...OK Checking security...OK Reading Partition table...OK Reading SBL...OK SBL type: Original, version: R8A029 Reading TA...OK Backup saved to "C:\Arquivos de programas\GsmServer\Octopus_Suite\BACKUP \Sony Ericsson_E10a_20-08-2012_13-52-30.BKP" Checking TA...OK Old IMEI: 012313-00-574245-0 New IMEI: 012313-00-574845-7 Replacing SBL...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...OK Receiving TA...OK Writing security area...OK Finalizing...OK Checking bootloaders... Check succesfully completed! Checking TA... Check succesfully completed! Rebooting device...OK IMEI sucesfully repaired! |
The Following User Says Thank You to rochater For This Useful Post: |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
