07-06-2012, 14:07 | #1 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,345 | Octopus Suite v1.0.8 - public discussion thread Octopus Suite v1.0.8
Supported for direct unlock devices and firmware versions:
Please note! If you have E153u-1, E153u-3, E173u-1 devices with unsupported for unlock firmware version, you can re-flash your device with unlockable firmware from the support area and then perform unlock procedure. Not all devices can be re-flashed! Write Firmware feature is available only for Octopus/Medusa card owners (Octopus/Medusa box should be connected to your PC). Download Octopus Suite v1.0.8 Last edited by Gsmserver; 07-06-2012 at 14:14. |
The Following 53 Users Say Thank You to Gsmserver For This Useful Post: |
07-06-2012, 14:39 | #3 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Republic of Mindanao
Member: 990900 Status: Offline Thanks Meter: 540 | i try to unlock my Globe tattoo but failde and also i flash the modem then i try unlock failde -------------------------------------------------------------------------------- Platform: Huawei Qualcomm Selected model: E153 Selected diagnostic port: COM11 Selected modem port: COM13 Reading info...OK Mode: Normal Model ID: KPRBL Firmware compiled date: Nov 03 2010 Firmware compiled time: 10:25:25 Firmware released date: Nov 03 2010 Firmware released time: 10:25:25 SW Version: 11.609.13.03.158 IMEI: 352374-04-690322-8 Detected manufacturer: huawei Detected model name: E153 Firmware version: 11.609.13.03.158 IMEI: 352374-04-690322-8 Connecting to server...OK Username: Authorizing...Failed! Login error: Wrong username! -------------------------------------------------------------------------------- IMEI: 352374-04-690322-8 Connecting to server...OK Username: Authorizing...Failed! Login error: Wrong username! Last edited by Code:L.A 22; 07-06-2012 at 14:45. |
07-06-2012, 14:56 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ Code:L.A 22 You can use default account: Username: Default_user Password: 1eqp4ax |
07-06-2012, 14:56 | #5 (permalink) |
No Life Poster Join Date: Feb 2012 Age: 39
Member: 1724862 Status: Offline Thanks Meter: 448 | Welcome to Octopus Suite version 1.0.8 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- IMEI: ***** Connecting to server...OK Username: Authorizing...Failed! Login error: Wrong username! -------------------------------------------------------------------------------- IMEI: *** Connecting to server...OK Username: Authorizing...Failed! Login error: Wrong username! |
07-06-2012, 15:04 | #6 (permalink) | |
Member: 1724862 Status: Offline Thanks Meter: 448 | Quote:
-------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: LT15i Operation: Repair IMEI Connecting to server...Failed! -------------------------------------------------------------------------------- Connecting to server...Failed! Your IP is in black list! dear gsmserver team helpp | |
07-06-2012, 15:05 | #7 (permalink) | |
Member: 990900 Status: Offline Thanks Meter: 540 | Quote:
-------------------------------------------------------------------------------- Platform: Huawei Qualcomm Selected model: E153 Selected diagnostic port: COM20 Selected modem port: COM22 Reading info...OK Mode: Normal Model ID: KPRBL Firmware compiled date: Nov 03 2010 Firmware compiled time: 10:25:25 Firmware released date: Nov 03 2010 Firmware released time: 10:25:25 SW Version: 11.609.13.03.158 IMEI: 352374-04-690322-8 Detected manufacturer: huawei Detected model name: E153 Firmware version: 11.609.13.03.158 IMEI: 352374-04-690322-8 Connecting to server...Failed! | |
07-06-2012, 15:07 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You have entered incorrect Username/Password 5 times, so your IP now is in black list for 30 minutes. Please try again in 30 minutes. |
07-06-2012, 15:08 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ Code:L.A 22 Please disable your antivirus and firewall (if they are running) and try again. Also, as You can see, firmware version in your device is not supported for unlock. |
07-06-2012, 15:09 | #10 (permalink) | |
I do not have a user name and password box is activated unlimited | |
07-06-2012, 15:15 | #11 (permalink) | ||
this default_user account you can use this any one them of user of octopus box Quote:
-------------------------------------------------------------------------------- Platform: Huawei Qualcomm Selected model: E153 Selected diagnostic port: COM20 Selected modem port: COM22 Found diagnostic port: COM20 Found modem port: COM22 Reading info...OK Mode: Normal Model ID: KPRBL Firmware compiled date: Nov 03 2010 Firmware compiled time: 10:25:25 Firmware released date: Nov 03 2010 Firmware released time: 10:25:25 SW Version: 11.609.13.03.158 IMEI: 352374-04-690322-8 Detected manufacturer: huawei Detected model name: E153 Firmware version: 11.609.13.03.158 IMEI: 352374-04-690322-8 Connecting to server...OK Username: Default_user Authorizing...Failed! Login error: Wrong password! | ||
07-06-2012, 15:26 | #14 (permalink) |
Member: 990900 Status: Offline Thanks Meter: 540 | -------------------------------------------------------------------------------- Platform: Huawei Qualcomm Selected model: E153 Selected diagnostic port: COM20 Selected modem port: COM22 Found diagnostic port: COM20 Found modem port: COM22 Reading info...OK Mode: Normal Model ID: KPRBL Firmware compiled date: Nov 03 2010 Firmware compiled time: 10:25:25 Firmware released date: Nov 03 2010 Firmware released time: 10:25:25 SW Version: 11.609.13.03.158 IMEI: 352374-04-690322-8 Detected manufacturer: huawei Detected model name: E153 Firmware version: 11.609.13.03.158 IMEI: 352374-04-690322-8 Connecting to server...OK Username: Default_user Authorizing...OK Octopus smart card and DreamBox are not present. Checking balance...OK Checking operation...OK Checking firmware version...OK Switching to emergency mode...OK Sending loader...OK Waiting for loader...OK Communicating with loader...OK Loader version: Octopus loader v.1.0.0 Initializing flash...OK Flash type : NAND Flash ID : 00A10098 Flash vendor: Toshiba Flash size: 128 Mb NAND page size: 0x800 NAND spare size: 0x40 NAND pages per block: 0x40 NAND blocks count: 0x400 Requesting additional data...OK Looking for patches...OK Searching for signature 1/8...OK Searching for signature 2/8...OK Searching for signature 3/8...OK Searching for signature 4/8...OK Searching for signature 5/8...Failed! Last edited by Code:L.A 22; 07-06-2012 at 15:31. |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
winlock 1.0 | Aldrin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 01-25-2000 04:49 |
cellular data suite kabel | vingis | Main Sales Section | 0 | 11-25-1999 19:18 |
Cellular Data Suite Cables avaliable !!! | vingis | Main Sales Section | 0 | 11-02-1999 17:35 |
download Datasuite 3.0 | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 10-31-1999 01:35 |
