01-22-2019, 18:21 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: yemen
Member: 346934 Status: Offline Sonork: 100.1575675 Thanks Meter: 59 | problem when unlock x10a [Solved] how are you what problem and how solve when unlock alwyas stop at Initializing flash...OK help me Welcome to Octoplus Suite version 1.5.8 -------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: X10a Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung, SE Unlimited Username: ufs4new Authorizing...OK Checking balance...OK Your balance: 10 credits. To unlock X10a you need to have 0 credits. Disconnect USB cable and power on the phone. Select menu "Settings"- >"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: CB511MZNM9 Device status: ACTIVE Kernel version: 2.6.29 Firmware version: Kernel version is supported Checking root access... Device is already rooted. Initializing flash...OK ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: X10a Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung, SE Unlimited Username: ufs4new Authorizing...OK Checking balance...OK Your balance: 10 credits. To unlock X10a you need to have 0 credits. Disconnect USB cable and power on the phone. Select menu "Settings"- >"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: CB511MZNM9 Device status: ACTIVE Kernel version: 2.6.29 Firmware version: Kernel version is supported Checking root access... Device is already rooted. Initializing flash...OK ------------------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: X10a Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung, SE Unlimited Username: ufs4new Authorizing...OK Checking balance...OK Your balance: 10 credits. To unlock X10a you need to have 0 credits. Disconnect USB cable and power on the phone. Select menu "Settings"- >"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: CB511MZNM9 Device status: ACTIVE Kernel version: 2.6.29 Firmware version: Kernel version is supported Checking root access... Device is already rooted. Initializing flash...OK |
