SK17i unlock testpoint problem SK17i 11W30 so i am having trouble with octopus suite when it comes to unlocking. it always hangs at the testpoint step, here is what i mean Welcome to Octopus Suite version 1.0.8 -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: SK17i Connecting to server...OK Octopus smart card and DreamBox are not present. Username: xXxXxxxxxXXx Authorizing...OK Checking balance...OK Your balance: 8billion credits. To unlock SK17i you need to have 8 credits. -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: SK17i Please, reconnect battery, attach testpoint and connect USB cable... anyway i do have valid credits for octopus but cant seem to get past the testpoint part with octopus software. if anyone else is having this problem and had it sorted, please any help would be appreciated thanks |
Hello. Please connect test point correctly accordingly to the pinout picture (press "Help" button in software) - when You do this correctly, new device Qualcomm USB QDLoader should appears in PC Device Manager. |
does it mean anything if its coming up as ZEUS flash device? do i have to uninstall default drivers and update drivers to the ones in octopus folder? |
Yes, You are right. Need to install driver from Octopus Suite folder. |
ok so ive done that and have encountered another problem. i uninstalled default drivers and then installed octopus suite drivers here http://s9.postimage.org/vl90wylj3/asdf.png and this is what i get after installing while phone is connected in testpoint mode http://s8.postimage.org/a1xova14l/image.png resulting in sk17i in testpoint mode unable to work properly http://s14.postimage.org/f45ijbxap/image.png what am i doing wrong here? |
i have same problem !!! |
%QcomDevice90080% i have to restart pc but now is working with that driver. |
How do you guys fix this? |
Please try to re-boot PC and install drivers again. Also You can contact us, we will try to help You remotely via Team Viewer. |
