09-28-2012, 13:19 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Spain- Amposta
Member: 860275 Status: Offline Thanks Meter: 179 | Sony Ericsson U20i unlock problem. [Solved] Heer is the log: Welcome to Octopus Suite version 1.1.2 -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: U20i Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG Username: mykola1111_01 Authorizing...OK Checking balance... Checking operation...OK Your balance: 6 credits. To unlock U20i you need to have 4 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...Canceled. -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: U20i Octopus smart card is present. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...Canceled. -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: U20i Octopus smart card is present. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 4342353131515A443754 Device status: ACTIVE Reading info... Detected model name: U20i Firmware version: 2.1.1.B.0.5 Kernel version: 2.6.29 -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: U20i Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG Username: mykola1111_01 Authorizing...OK Checking balance... Checking operation...OK Your balance: 6 credits. To unlock U20i you need to have 4 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 4342353131515A443754 Device status: ACTIVE Reading info... Detected model name: U20i Firmware version: 2.1.1.B.0.5 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Checking security...OK Reading Partition table... Could not read SBL. Maybe, NAND MPU is enabled. Disabling NAND MPU...OK Reconnecting device. Please wait...OK Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 4342353131515A443754 Device status: ACTIVE Reading info... Detected model name: U20i Firmware version: 2.1.1.B.0.5 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Reading Partition table...OK Reading SBL...OK SBL type: Original, version: R8A029 Reading TA...OK Backup saved to "C:\Archivos de programa\GsmServer\Octopus_Suite\BACKUP \Sony Ericsson_U20i_28-09-2012_14-08-56.BKP" Checking TA...OK IMEI: 012468-00-537792-9 Replacing SBL...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...OK Receiving TA...OK Writing security area...Failed! -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: U20i Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG Username: mykola1111_01 Authorizing...OK Checking balance... Checking operation...Failed! Too low balance to provide the security operation! Your balance: 2 credits. To unlock U20i you need to have 4 credits. Please, help mi to unlock the phone, or return mi logs. Thx. Last edited by Octopus box; 09-28-2012 at 14:24. |
09-28-2012, 13:53 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please re-flash the phone with the firemware https://www.boot-loader.com/app/webr....0.6_WORLD.oct from the support area and try again. Try on another PC or on another USB port. P.S. We have added You +4 credits back. |
09-28-2012, 14:14 | #3 (permalink) | |
Member: 860275 Status: Offline Thanks Meter: 179 | Quote:
Username: mykola1111_01 Authorizing...OK Checking balance...OK Your balance: 6 credits. Octopus smart card is present. Checking smart card...OK Smart card activations: LG -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: U20i Please, reconnect battery, hold "back" key and connect USB cable...OK Reading info... Chipset: S1 MSM7227 IMEI: 012468-00-537792-9 MSN: CB511QZD7T Sending loader...OK Selecting output file...OK Destination file: "Sony Ericsson_U20i_01246800537792_28-09-2012_15-01- 35.TA" Reading TA_MISC...OK Reading TA...OK Shutting down...OK -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: U20i Opening "U20i_2.1.1.A.0.6_WORLD.oct"...OK Please, reconnect battery, hold "back" key and connect USB cable...OK Reading info... Chipset: S1 MSM7227 IMEI: 012468-00-537792-9 MSN: CB511QZD7T Sending loader...OK Writing Firmware... Writing AMSS...OK Writing AMSS_FS...OK Writing CACHE...OK Writing FOTA0...OK Writing FOTA1...OK Writing KERNEL...OK Writing SYSTEM...OK Writing USERDATA...OK Shutting down...OK -------------------------------------------------------------------------------- Platform: SE Qualcomm Selected model: U20i Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG Username: mykola1111_01 Authorizing...OK Checking balance... Checking operation...OK Your balance: 6 credits. To unlock U20i you need to have 4 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 4342353131515A443754 Device status: ACTIVE Reading info... Detected model name: U20i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Checking security...OK Reading Partition table... Could not read SBL. Maybe, NAND MPU is enabled. Disabling NAND MPU...OK Reconnecting device. Please wait...OK Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: 4342353131515A443754 Device status: ACTIVE Reading info... Detected model name: U20i Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Reading Partition table...OK Reading SBL...OK SBL type: Original, version: R8A029 Reading TA...OK Backup saved to "C:\Archivos de programa\GsmServer\Octopus_Suite\BACKUP \Sony Ericsson_U20i_28-09-2012_15-09-33.BKP" Checking TA...OK IMEI: 012468-00-537792-9 Replacing SBL...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...OK Receiving TA...OK Writing security area...OK Finalizing...OK Checking bootloaders... Check succesfully completed! Checking TA... Check succesfully completed! Rebooting device...OK Phone sucesfully unlocked! All Ok. Thnx. | |
The Following 2 Users Say Thank You to kineskop For This Useful Post: |
