To Alf Hi Alf , Thanks for the info got it working now simple when you know how just got to figue out how to switch cards without switching off then everthing is great Once again thanks Malcolm |
plz i need help i want to use sim_emu with sliver card but i want the rigth way to cut it and use it with 6210 coz it differ from the gold and funcard , the gold one and fun it's chip appers longtudinaly but the sliver gose horizntal. pls help this is the gold http://www.azeemacomputer.com/images/goldcard.jpg and this the sliver http://www.azeemacomputer.com/images/silver-876.jpg with regards |
Mate its easy as to cutout... Just trace around ur old sim with a sharp object and grab some sharp scissors... Thats all I did :) Takes 1 minute max :) and the cards arnt easy to crack if u are careful, I cut my mates out for him and its easy, just take it one small piece at a time (dont chop it right in half work ur way down to it) Happy cutting mate |
how to trace it , i already did it with gold and it works but with sliver the chip big and in another direction see the pic plz and thanx for replay and help |
][No_WaY goes cutting ... There are two types of silver cards: some with normal contacts (maybe 16F876) and others with extended contacts (maybe 16F877). Both work well. :) Of course, the template of cuts are the same for both models, and the size of the microsims (after the cuts) obviously it is the same one. For your model, the long cuts coincide exactly with the limit of the golden area of contacts. This is a problem in a few telephones that have a microsim connector with a metallic frame. Here, there is a short-circuit risk.:( |
in this way? 1 http://www.us.f1.yahoofs.com/users/a...2RE58ArXMzhg3N or this 2 http://www.us.f1.yahoofs.com/users/a...2RE58APeJC9G1m or this 3 http://www.us.f1.yahoofs.com/users/a...2RE58AxxJPcGSW thanx |
Use this guide: http://www.mobileshop.org/usertech/simcutting.htm Don't worry about the size of the contact area being larger than a normal SIM. If you're careful and follow the guide exactly it will work fine. |
thanx paul i make it as the manual but after insertion in motorola it gives me check card but it was work before cutting . i try to program it agin but win i use twoprog as i did before it gives me error while uploding eeprom loder! that's the card is dameged? |
To Simemu Hi wonder if you could help me .Is there a way of switching between cards/providers without switching the phone off and back on then entering new pin. I have a nokia 3330 and the command *3370# doesn't seem to work on ver 4.01 if I remember correctly *3370# worked on ver 4.0. Thanks in advance regards Malcolm |
When cutting you have to be very careful, and use a sharp knife to avoid putting too much stress on the card. You're cutting quite close to the die so if there's too much bending you can damage it. The first card I cut using those instructions no longer worked, but I have since done two more and both work fine. It is a risky process but unfortunately unless someone makes SIM-sized gold or silver cards (which is unlikely) there's no other option. |
SIM-EMU 4.01 hi there dose any one can tell me how can i use SIM-EMU 4.01 or how can i downloaded to my handy(my handy is nokia 6310i) and what the hardeware do i need to use it with SIM-EMU 4.01. note i have multiprogramer2001xl is this can work? thanks for all cut_r2000http://www.electronic-devices.com/im...1xl-normal.gif |
If *3370# does not to work in 4.00 in your phone, then in the 4.01 does not work too. This is a general problem of all Nokia, the Refresh command is not correctly implemented in the soft of the phones, sorry. Switch from the menu and then force the find of the network again. Regards |
????? Quote:
To use SIM-EMU, you need a SilverCard/GreenCard to write in it the SIM-EMU soft. To write the soft in the card, you need a TE-20 to program the flash and a Phoenix to program the external EEPROM. I don't know if your programmer is able to do this task. Regards |
Everyone should get thenselves an 'Elvis Multiprogrammer' they program just about every standard card available!! |
