Question about cloning hi i'm new here i wanted to know what are the advantages of sim cloning except doing backup of your own sim. is it possible to steal someone line even if you never touched his sim? |
"NO!" :p 123456789123456789 |
If I clone multiple SIM cards, Can I use the lines on them? Also, Will my mobile phone display all the available networks on the screen or do I need to turn OFF the phone to select which network will display? |
The switching of the numbers can be done through a new menu that will appear on your mobile ('Select phone #'). You will not have to turn off your phone and log in with a different pin, but you can do it this way as well. The "select phone #" menu does not work on every model without "reboot" of the phone. If the menu will work on your phone, expect about 10 seconds for the switching from one number to the other. The "active" phone number will appear on the display with a note that you can define.... My phone i.e. displays "NETWORK" and below that the active number "+691234567" |
so what can i do with cloning what can it give for me? |
if you don't find a reason on your own, then you don't need a clone at all. You might want to read this to get some ideas what it could be usefull for: http://forum.gsmhosting.com/vbb/show...5&postcount=12 |
Hello Ch@in, what is the solution now for cloning sims into 1??? I have 4 lines of 4 diffrent operators(plus 2 other lines from a diffrent countries) I don't want to be holding 4 hansets as it's expensive to maintain or buy 4 handsets @ the same time. Forgot 1 home or forgot to charge 1 of them, fell down... Turning off 1 switching the sim, or loose the sim....... the list never ends I want to be having 1 sim with all my lines in it & will be chosing wich 1 to use. It was possible before but now with V2 i guess it's not. So what is the solution????? What is illegal in having 1 sim with all the lines that i have??? Any coming solutions or a solution that i'm not aware of ??? |
In my opinion, the best thing to do is find an OLD simcard (v1) from the network you want, and ask the network-provider to convert that number from prepaid to subscription WITHOUT ISSUING A NEW SIMCARD. Maybe some of your friends still have working V1 prepaid sims that you could buy from them or exchange for a new USIM card. Good luck |
Hi, RAMIRAMI My advantages of cloning are: I have 3 simcards, of 3 different operators (vodafone, tmn, optimus) now my telephone only gives for 1 simcard... OK? Comprende my friend ? Best regards FClone from Portugal |
More, I can still have up to 12 nš of telephone of any 3 operators ( in the same smartcard off course ) Regards |
And more I have of the double of phone book entries, and of the triple of sms since you see, that is wonderfull.because the original sim has very little memory From Portugal.............bye |
