Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Sim Cloning and Scaning
Old 05-30-2003, 12:46   #1 (permalink)
Member: 11995
sim card not accepted after simemu 6
Hi,
I have green2 card with simemu 6,and allways says "sim card not accepted".With simemu 5 is all OK.Can anybody help me?
I did try a lot of phones,and result is same.
Where I doing a mistake?Card is configured like green card ,250 ADN,40SMS,10 FDN.
Thank you!
Tina
sorry my bad english...
Old 05-30-2003, 15:37   #2 (permalink)
Member: 17102
Hi, ur problem is opposite mine.
I've programmed my GC2 only one time and it works fine.
After programmed my 1 SC and 1 GC with v600 by configuring ADN, FDN, SMS for each kind of cards, no problem occur while programming, all successfully verified, but they don't work on my phone with the message "Simcard rejected" !!!!!!! After reprogramm for many times also no problem but they still don't work !!!!!
Any suggestion for solving this problem will be much appreciated.
Regards,
Old 05-30-2003, 21:34   #3 (permalink)
Member: 15414
the same happens to me
Old 05-30-2003, 22:05   #4 (permalink)
Member: 17102
Hi all,
OK, after trying to reprogram by changing some settings, this time after programmed and insert card to phone it works!! Asking for Enter PIN number instead of "Simcard Rejected".
..... I change IC-Prog from v1.05a to 1.05.
Before clicking Program, I select CP Off in the Code Protect Box...
This method makes my cards work ( 4 cards, 3 SC and 1 GC)
but I don't know is there any problem hiding inside, just let me test for sometimes and I'll let you know the final results.
Regards.
Old 05-30-2003, 22:33   #5 (permalink)
Member: 17102
Hi all,
Regards.
Old 05-31-2003, 14:11   #6 (permalink)
simemu's Avatar
Member: 10582
Thanks Meter: 99
The card is rejected if the version put in the card does not correspond with the type or the files was not correctly written.
The SIM-EMU hang itself if it detects incorrect file versions.
Regards
Old 05-31-2003, 21:39   #7 (permalink)
Member: 17102
@Sim_Emu
Could u pls explain the difference between 1 SC programmed by CP Off and 1 SC by your default.
Now, I can programm my SCs successfully with CP Off and CP by default by setting ADN=150, SMS=15, FDN=5 and all these cards work properly.
I notice that with IC-Prog v1.05a, no problems when programming but these cards won't work when put in the phone.
With IC-Prog v1.05, all my cards work after programming. I've tested for many many times. I don't know why?
Regards.
Old 06-01-2003, 15:36   #8 (permalink)
simemu's Avatar
Member: 10582
Thanks Meter: 99
Activating the protection of the last 256 bytes of the flash, it makes impossible to write the flash again without making a total erasure.
With this protection, it is impossible to write a special program capable to read our KI's located in the internal EEPROM.
I use ICProg 1.05A without any problem all the times.
If you want, try to contact with the author.
Regards
Old 06-01-2003, 15:54   #9 (permalink)
Member: 15414
With me, now it's working fine, version 6.00 and 6.00s, and i use icprog 1.04.
The problem of every one, i think because it happens to me, is when configuring the flash filie.
1) input langunage prefix in the config program that is in teh zip of simEmu 6.00
2) select box with 6.00, or s or g
3) select number of ADN, FDN and SMS
4) click on the buton to update.
and then it should work
Old 06-01-2003, 17:08   #10 (permalink)
simemu's Avatar
Member: 10582
Thanks Meter: 99
That is that I said in another post.
Enter the prefix language (this reads the flash and show the file data), then enter the rest of the fields and press Update.
Regards
Old 06-02-2003, 12:37   #11 (permalink)
Member: 11995
RE
Hi,
How to erase green card?Allways when erase card with option ic-prog says card erased.After that when I write simemu 5 allways card is "live" like before.
Tina
Old 06-03-2003, 10:19   #12 (permalink)
Member: 30230
Thanks Meter: 3
6.00s not working on my phone
Yes, I tried everything, but SimEmu6.00s do not work on my Nokia6210 (sim rejected).
I did:
1) input language suffix (ENG) in the SIM_EMU_6.00_CFG.exe
2) select radio button 6.00s
3) select number of ADN (151), SMS (10), FDN (47)
4) click on the buton "Update SIM_EMU_FL_6.00_ENG.hex"
5) "SIM_EMU_FL_6.00_ENG.hex Patched OK!"
6) programmed eeprom on silver card with SIM_EMU_EP_6.00.hex (with dejan's programmer, but first I opened eeprom file with IC-PROG and then saved under same name but for eeprom 24c64)
7) programmed pic with SIM_EMU_FL_6.00_ENG.hex (several succesfull attempts, with dejan's programmer, with IC-PROG cp-on, cp-off, ...)
But, everytime when I try to use sim, my phone reject it!
With 5.00s everything work fine.
I did everything right, didn't I? Where is a mistake?
Old 06-03-2003, 16:37   #13 (permalink)
simemu's Avatar
Member: 10582
Thanks Meter: 99
How did you program the external EEPROM ?
Are you sure it is ok ?
Does the phone ask the PIN ?
If the message is SIM Rejected before ask the PIN, the card is not correclty programmed.
Old 06-03-2003, 19:29   #14 (permalink)
Member: 30230
Thanks Meter: 3
Yes...
I programmed external eeprom, through dejan's programmer. The same procedure (dejan's programmer) I'm using when I'm programming SimEmu5.00, and have no problem with that version. I programmed pic flash memory several times also with IC-PROG (which can working with dejan's programmer hardware), and again no problem with 5.00, but with 6.00 card rejected.
With SimEmu6.00, card DON'T ask for PIN, just waiting some (long) time, and then pop up message "SIM REJECTED". When card is blank (erased flash on pic) then phone don't wait that long time, instead instant show message "INSERT SIM"
I even tried following combinations:
1) programmed silver eeprom with 5.00 eeprom file and pic with 6.00 flash file:
Same result "SIM REJECTED"
2) programmed silver eeprom with 6.00 eeprom file and pic with 5.00 flash file:
Card ask for PIN, and working (!), but some of proactive menus (Sim-Emu5.00) don't work
So, my conclusion (from this testing) is that 6.00 flash file is problem, because 5.00 flash with 6.00 eeprom partialy working and asking for PIN!
I did everything right, step by step, while configuring 6.00 flash for silver card. I don't know where is a problem. I did configuring 10-20 times, and always same results.
Old 06-03-2003, 20:36   #15 (permalink)
simemu's Avatar
Member: 10582
Thanks Meter: 99
The 6.00 flash has no problem.
There are many people using it.
The 6.00 checks the correct writing of the external EEPROM, if it is not ok, it don't work.
For this reason, I suppose that your problem is in the external EEPROM programming.
Can you read the external EEPROM written in the card using the Dejan programmer ?
Try to use a Phoenix programmer to program the EEPROM.
PD: Don't mix the external EEPROM files between versions.
Regards
SIM Card not accepted after Eeprom Tools 3.1 AlphaRomeo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-02-2002 21:37
Sim card Not Accepted 6150 V 5.02 hares14 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 01-06-2002 21:42
Change IMEI problem - Sim Card Not Accepted TheEckoMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 09-02-2001 12:50
3810 sim card not accepted wild Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-07-2001 09:29
NOKIA 5110 5.29 all locks OPEN but SIM CARD NOT ACCEPTED elektron code ECS Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-10-2001 17:40
Page generated in 0.27697 seconds with 9 queries
