11-07-2014, 15:16 | #1 (permalink) |
Insane Poster Join Date: Feb 2011
Member: 1522423 Status: Offline Thanks Meter: 4 | galaxy s4 mini unlock problem [07/11/2014 13:50:44] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... GBKey Samsung Unlocker 1.72 Model selected : Samsung GSM Port selected : USB Serial Port (COM7) Using port COM7... Reading info... Error sending command !!! |
11-07-2014, 15:53 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | read a little in forum and use SEARCH botton and you get answer http://forum.gsmhosting.com/vbb/10641683-post55.html |
11-07-2014, 16:07 | #4 (permalink) |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | if you did cover VF battery connector, phone will be detected with SW.. if you are sure you did do well operation, so, check your rj45 cable, box etc etc this phone has been unlocked by other users, so it should work for you too br |
11-07-2014, 17:43 | #7 (permalink) |
Member: 1522423 Status: Offline Thanks Meter: 4 | i can read that but people have had the same issue as me and i was asking to see if anyone had a sensible answer to the problem not just the usual check your leads and box so if you cant help dont bother replying |
11-07-2014, 19:46 | #8 (permalink) |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | there is no sensible answer....the unique answer is that problem is from your side..... you got to point to other post / people that get same issue, and not again and again ask same, getting answer clear..so, I think you did bother Asking this is becoming lost of forum space.... thread closed |
