11-17-2016, 20:04 | #1 (permalink) | ||
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | >>>Try It, but no work for me!!!<<< Quote:
Try to imei repair huawei VNS-L23..how try it gbkey???? Plase helpme!!! | ||
11-17-2016, 20:13 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | because you did do Read Info before doing Repair Imei. Read info is also 1 Operation...so Do directly Repair imei. we did explain this in many posts, and we did explain that some models do need more than 1 connection to server. thus are not supported for TRY ME Mode. Hope is clear..Try tomorrow, and do REPAIR IMEI without Read info. Hope your phone need 1 time server connection, if needs more, you will get also same Response. Br |
11-17-2016, 20:19 | #3 (permalink) | |
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Quote:
Thanks for faster answer.... | |
11-17-2016, 20:25 | #4 (permalink) |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Try always read a little this forum, that do help much http://forum.gsmhosting.com/vbb/12121843-post12.html Br |
11-20-2016, 00:32 | #5 (permalink) |
No Life Poster Join Date: Jan 2006 Location: algeria
Member: 217891 Status: Offline Thanks Meter: 237 | i try for same but get error [19/11/2016 23:29:02] GBKey Huawei Pack4 1.27 Detecting... Detected : (Qualcomm) DBAdapter Reserved Interface (COM283) Authenticating... Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... Authentication Passed Reading Info... ---------- Version Info ----------- SCL-L01C368B130_BOOT MSM8909C900B130_AMSS Sep 9 201518:08:56 SCL-L01_C00B007_EFS_RFNV_B05 HL3SCALEM SCL-L01C368B130_APPSBOOT SCL-L01C368B130_KERNEL SCL-L01C368B130_SYSTEM SCL-L01C368B130_RECOVERY MSM8909 HUAWEI SCL-L01 C368 D002 MSM8909_SCL_L01_ ----------------------------------- IMEI : 86xxxxxxxxxxxxxx SN : 7N3FSE15CC096853 BT : 00:00:00:00:00:00 Wifi : 00:00:00:00:00:00 Bootloader code : None Unlocking... MSM8909 Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... GBKey not active for pack4 !!! Unlock Failed !!! Finished. |
