04-05-2014, 12:15 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1042497 Status: Offline Thanks Meter: 40 | i9100 repair boot error Set definition done! Writing in progress(make sure to press Power On key)... CPU ID: 7704A04B. Flash1 ID: 00150001, Flash Size: 03AB400000 (15028M / 14.68G). Flash2 ID: 00150001, Flash Size: 0000080000 (512K) Release Power on key now and operation continues... Error 11 phone doesn't respond for a long time,please reconnect! Time: 21 s i need help |
04-05-2014, 13:30 | #3 (permalink) |
Member: 1042497 Status: Offline Thanks Meter: 40 | I did that still same peoblem Flash1 ID: 00150001, Flash Size: 03AB400000 (15028M / 14.68G). Flash2 ID: 00150001, Flash Size: 0000080000 (512K) Release Power on key now and operation continues... Error 11 phone doesn't respond for a long time,please reconnect! |
04-05-2014, 13:44 | #4 (permalink) |
Member: 1042497 Status: Offline Thanks Meter: 40 | writing was successful and still same problem can you help me Writing in progress(make sure to press Power On key)... CPU ID: 7704A04B. Flash1 ID: 00150001, Flash Size: 03AB400000 (15028M / 14.68G). Flash2 ID: 00150001, Flash Size: 0000080000 (512K) Release Power on key now and operation continues... Write succeed! |
04-05-2014, 14:31 | #5 (permalink) |
Member: 1042497 Status: Offline Thanks Meter: 40 | i9100 repair boot done but I still have the same problem I have I9100 I did a repair boot and it was successful but still the phone is dead it draws some power then shuts down I need the DUMP FILE i9100 ...... ? Writing in progress(make sure to press Power On key)... CPU ID: 7704A04B. Flash1 ID: 00150001, Flash Size: 03AB400000 (15028M / 14.68G). Flash2 ID: 00150001, Flash Size: 0000080000 (512K) Release Power on key now and operation continues... Write succeed! i write ... Samsung i9100 and M250S general rom2.3.4 backup 1G.bin and Samsung_i9100_Boot(2012_5_14_NEW).bin i have wrote the 2 files and i get a message done and i have the same problem |
04-05-2014, 17:09 | #6 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Maharagama, Srilanka
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | if you write this Samsung i9100 and M250S general rom2.3.4 backup 1G.bin now phone should be on condition if phone haven't hardware fault.now you have to check phone hardware side and check phone history too |
