04-16-2012, 13:10 | #2 (permalink) |
No Life Poster Join Date: Jul 2007 Location: (¯`». Catch Me If U Can .«´¯) Age: 35
Member: 553445 Status: Offline Sonork: 100.1585581 Thanks Meter: 8,184 | Try this fimrware and post result GT-S7230E Country/Carrier: Open Europe Date: 2012 February Firmware: BADA 2.0 |
04-16-2012, 19:01 | #3 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | S7230e SPT here's the procedure how to repair IMEI and Unlock S7230e using SPT box Quote:
Regardz.... | |
04-17-2012, 08:21 | #4 (permalink) | |
Registered User Join Date: Sep 2002 Location: No Man's Land
Member: 15858 Status: Offline Thanks Meter: 10 | Quote:
hi, thanks but same problem it seems problem is not in firmeware, perhaps in repaired boot ! br | |
04-18-2012, 20:45 | #9 (permalink) | |
Banned Join Date: Nov 2009 Location: Lima, Perú
Member: 1159099 Status: Offline Thanks Meter: 6,371 | Quote:
try with this http://forum.gsmhosting.com/vbb/8287899-post1.html Regards Pablo A. | |
04-19-2012, 05:31 | #11 (permalink) | ||
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | Quote:
repair imei using spt box | ||
04-14-2015, 10:40 | #13 (permalink) |
Insane Poster Join Date: May 2013
Member: 1946652 Status: Offline Thanks Meter: 14 | MY PROBLEM SOVE THIS PROCESS BLINK OR FLASH AND AFTER IMEI WRITE * Check firmware in phone by code *#1234# * Download Flash File At Support Area the same version or higher then is in phone. * Select any Boot file inside Flash folder (BOOTFILES directory). * Mark Reset Mslcode 16 * Put phone Download mode ( VOL UP + HOLD + POWER ON ) * Connect usb to phone select modem port ( port com in SW that in device manager is samsung modem) * Press Write and After Job Done * Again Put Download Mode and Write boot with untick Reset mslcode 16 * Connect phone powered to usb cable and select IMEI(in box write org IMEI or other like you need) , select UNLOCK and Press Factory mode |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
Only MAX232 ??? | AMIGO | Nokia Hardware & Hardware Repair | 7 | 04-12-2000 09:41 |
6110 unlocked but wont give reception | KingOfKingston | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-10-2000 22:15 |
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed | spterminator | Main Sales Section | 0 | 08-08-1999 05:08 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
