Old 07-10-2015, 02:41   #1 (permalink)
Member: 525940
Thanks Meter: 213
lenovo a319 after flash dead (Replied & Closed)
Old 07-10-2015, 03:54   #2 (permalink)
Member: 350571
Thanks Meter: 920
tell me your phone
HW version and SW version
this detail you can get from back side of the phone on imei sticker
The Following 2 Users Say Thank You to sree krishna For This Useful Post:
Old 07-10-2015, 04:21   #3 (permalink)
Member: 350571
Thanks Meter: 920
download firmware which one matching you
Then Flash with Miracle
if not success
put phone into boot mode or use miracle boot jig then flash with miracle
your problem will be solve 100%
Lenovo_A319_S232_140926
Lenovo_A319_S234_141018
Lenovo_A319_S305_141125
Lenovo_A319_S308_150115
The Following 3 Users Say Thank You to sree krishna For This Useful Post:
Old 07-10-2015, 08:06   #4 (permalink)
Member: 350571
Thanks Meter: 920
sorry above post download link is missing i added download links here
The Following User Says Thank You to sree krishna For This Useful Post:
Old 07-10-2015, 23:21   #5 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
bro did you made its backup? flash with backup file and see set alive or not if not then i think preloader is dead in this case you should erase whole flash and try to flash again with good firmware and post result
Old 07-11-2015, 02:08   #6 (permalink)
Member: 525940
Thanks Meter: 213
i used back up from good a319
this is the details at the sticker
Model:Lenovo A319 MID: 31900030
Lenovo Mobile Phone
Manufactured for Lenovo PC HK Limited
Made in China
Complies with
IDA Standards
DB102306
IMEI1:867347027833117
IME12:867347027833110
S/N:HGEG8J2R(90)
CE0700
The Following User Says Thank You to eumore79 For This Useful Post:
Old 07-12-2015, 15:25   #7 (permalink)
Member: 570252
Thanks Meter: 207
Question
Lenovo Mobile Phone
Made in China
Complies with
IDA Standards
DB102306
S/N:HGEG8J2R(90)
CE0700
have same set here
which version worked for u ???
Old 07-13-2015, 02:39   #8 (permalink)
Member: 525940
Thanks Meter: 213
not yet try the firmware. got slow connection. need to download the firmware. if you succeed let us know
Old 07-15-2015, 05:30   #9 (permalink)
Member: 525940
Thanks Meter: 213
problem is still the same. i can't flash it with flashtool or erase with flashtool
i can write the firmware with miracle box but unit is still dead
Old 07-15-2015, 06:34   #10 (permalink)
Member: 1764566
Sonork: SUSPENDED
Thanks Meter: 5,763
problem is still the same. I can't flash it with flashtool or erase with flashtool
can i pz post logs of miracle box
Old 07-15-2015, 07:00   #11 (permalink)
Member: 1716692
Thanks Meter: 9
Smile try this firmware
u just download this file..then extract...then select scatter file only then write...my problem already done bro..enjoy...
link here...https://cloud.mail.ru/public/3VSDucZ...S312_150330.7z or go to moulnisky or androidxda
The Following 2 Users Say Thank You to Rafeekchalingad For This Useful Post:
Old 07-16-2015, 03:40   #12 (permalink)
Member: 525940
Thanks Meter: 213
you use miracle box to flash this firmware or use flashtool?
Old 07-21-2015, 02:16   #13 (permalink)
Member: 525940
Thanks Meter: 213
i use this files but phone still dead
any help?
Old 07-21-2015, 03:20   #14 (permalink)
Member: 1427706
Thanks Meter: 16
brother flash ur cp in sp flash tool go to advance option then format it and forcedly remove bad locks
Old 07-21-2015, 03:21   #15 (permalink)
Member: 1427706
Thanks Meter: 16
The Following User Says Thank You to rvin_09 For This Useful Post:
Page generated in 0.24059 seconds with 8 queries
