Miracle Box GSMCampus |
01-16-2016, 11:54 | #18 (permalink) |
No Life Poster Join Date: Dec 2007 Location: INDIA _ TAMILNADU _ KUMBAKONAM
Member: 667142 Status: Offline Sonork: +919655528882 Thanks Meter: 2,495 | WORLD FIRST Lava Iris X1 Beats SPD7731GEA Read & Write Flash ( Updated Firmware )Done WORLD FIRST Lava Iris X1 Beats SPD7731GEA Read & Write Flash ( Updated Firmware ) Done 👊“ BY ”👊 Read Flash ( Backup ) Select Block Write Flash Done After Done ( Device Info ) |
The Following 8 Users Say Thank You to ATHI For This Useful Post: |
01-16-2016, 12:37 | #23 (permalink) |
No Life Poster Join Date: Oct 2007 Location: IN MOBILES
Member: 613242 Status: Offline Sonork: 100.1626311 Thanks Meter: 645 | 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set PreLoader USB VCOM Port (COM8) Please Hold "ON" to connect with the phone... Unstable USB port Definition Applied |
01-16-2016, 12:38 | #24 (permalink) |
Member: 613242 Status: Offline Sonork: 100.1626311 Thanks Meter: 645 | 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set PreLoader USB VCOM Port (COM8) Please Hold "ON" to connect with the phone... Unstable USB port Definition Applied Unstable USB port any solution for this many cpu problem show some time working perfect mostly in 6571 cpu prob show when i write imei |
01-16-2016, 12:50 | #25 (permalink) | |
Banned Join Date: Nov 2012 Location: unknown
Member: 1837438 Status: Offline Sonork: unknown Thanks Meter: 659 | Quote:
01-16-2016, 12:51 | #26 (permalink) | |
No Life Poster Join Date: Jun 2014 Location: Ghana Age: 31
Member: 2207285 Status: Offline Thanks Meter: 127 | Quote:
01-16-2016, 12:51 | #27 (permalink) | |
