Miracle Box GSMCampus |
09-03-2018, 05:36 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Turkmenistan
Member: 1817753 Status: Offline Thanks Meter: 19 | Redmi s2 FRP reset Problem (Replied & Closed) Please Remove SIM & Close Wifi Checking Security Searching and Uploading data Starting.. Selected Brand : Auto Detect Selected Model : Qualcomm Android(Qualcomm) # Before Start Must Install Drivers. Check Driver : Index of ./__/ # Device Must Be Connected with EDL Mode. # Hold Volume UP + DOWN and Insert USB Cable to Device. # Battery Must Charge More then 50% # Some Mobile Need Miracle EDL Jig # Some Mobile Need Test Point 1 : Power off Phone.. 2 : Press Volume up and Down and connect Usb cable.. Auto detecting Port.. Phone Found on Port [COM10] Reading Info.. Auto Detection Enabled.. Found : MSM8953 Serial : 0x91fc6f5d Hw Id : 0x000460e1 Hash : 0x57158eaf1814d78fd2b3105ece4db18a817a08ac664a5782 a925f3ff8403d39a Sbl Ver. : 0x00000001 Starting Remove Account Task... Memory type : Emmc Sending Loader.. Please Wait Error : Failed to Boot Loader.. Please Try Selecting Correct Loader in Settings Tab... Process Failed.. Code: Please Remove SIM & Close Wifi Checking Security Searching and Uploading data Starting.. Selected Brand : Xiaomi Selected Model : XIAOMI S2 YSL(Qualcomm) # Before Start Must Install Drivers. Check Driver : http://miraclesserver.com/miracle # Device Must Be Connected with EDL Mode. # Hold Volume UP + DOWN and Insert USB Cable to Device. # Battery Must Charge More then 50% # Some Mobile Need Miracle EDL Jig # Some Mobile Need Test Point 1 : Power off Phone.. 2 : Press Volume up and Down and connect Usb cable.. Auto detecting Port.. Phone Found on Port [COM10] Reading Info.. Auto Detection Enabled.. Found : MSM8953 Auto Detection Enabled.. Serial : 0x91fc6f5d Hw Id : 0x000460e1 Hash : 0x57158eaf1814d78fd2b3105ece4db18a817a08ac664a5782a925f3ff8403d39a Sbl Ver. : 0x00000001 Starting Remove Account Task... Memory type : Emmc Sending Loader.. Please Wait Error : Failed to Boot Loader.. Please Try Selecting Correct Loader in Settings Tab... Process Failed.. Code: Please Remove SIM & Close Wifi Checking Security Searching and Uploading data Starting.. Selected Brand : Xiaomi Selected Model : XIAOMI S2 YSL(Qualcomm) # Before Start Must Install Drivers. Check Driver : http://miraclesserver.com/miracle # Device Must Be Connected with Fastboot Mode. # Hold Volume Down and Power Button # Battery Must Charge More then 50% Waiting for Phone... Phone Found.. Protocol Version : 0.5 Serial No. : f00806dc Platform : ysl finished. total time: 0.003s Starting Frp Unlock.. Frp Unlock ok.. Rebooting.. Process Done.. Please Wait a Few Minutes the Mobile take time for Restarting. Last edited by [SV]; 09-03-2018 at 13:56. Reason: (Replied & Closed) |
