Turn-on the Phone Goto 'Settings > Application > Development'
And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver.
Prepairing ...OK
Device Found!
Model : GT-I9100
IMEI : NULL
tar: removing leading '/' from member names
efs/
efs/cryptprop_onetimeboot
efs/nv_data.bin
efs/lost+found/
efs/cryptprop_applied_result
efs/.files/
efs/.files/.mp301/
efs/.files/.dm33/
efs/.files/.dx1/
efs/dmp/
efs/dmp/sett/
efs/dmp/sett/secure/
efs/dmp/sett/system/
efs/dmp/sett/system/airplane_mode_on
efs/cryptprop_essiv
efs/cryptprop_securewipedata
126 KB/s (0 bytes in 12174.000s)
EFS Backed Up and saved in "C:/ASANSAM2/BACKUP/GT-I9100/NULL/EFS/TAR_GZ"
Operation Completed
Operation Time: 00:00:17
Prepairing ...OK
Device Found!
Root Procedure Started!
Refreshing ... OK
Prepairing ROOTFILE1(STEP 1) ... OK
Prepairing ROOTFILE1(STEP 2) ... OK
Prepairing ROOTFILE1(STEP 3) (Please Be Patient 'its take almost ~190 Sec')... OK
Reconnecting Device ...
if Procedure Stuck Here For a Long Time try This:
Disconnecting USB Cable From Phone then Go to:
'Settings > Application > Development' and Toggle 'USB Debugging' (Uncheck then Check)
Then Connect Cable to Phone
Device Found!
Prepairing ROOTFILE2(STEP 1) ... OK
Prepairing ROOTFILE2(STEP 2) ... OK
Prepairing ROOTFILE2(STEP 3) ... OK
Prepairing ROOTFILE2(STEP 4) ... OK
Prepairing ROOTFILE2(STEP 5) ... OK
Prepairing ROOTFILE2(STEP 6) ... OK
Prepairing ROOTFILE2(STEP 7) ... OK OK
Prepairing ROOTFILE3(STEP 1) ... OK
Prepairing ROOTFILE3(STEP 2) ... OK
Prepairing ROOTFILE3(STEP 3) ... OK
Prepairing ROOTFILE3(STEP 4) ... OK OK
Prepairing Final Step ... OK
Refreshing ... OK
Rebooting ... OK
Root Procedure Finished!
Operation Completed
Operation Time: 00:04:23
Prepairing ...OK
Device Found!
Prepairing Method 1 ... OK
Phone Reset Done!
Now When Phone Turn On please Enter *#06# Code to Phone if IMEI Appear Press Cancel
And Procedure Finished but if You Dont see IMEI Press Continue
Waiting For Command ... Continue
Prepairing Method 2 ...
=========> Step 1 ...OK
=========> Step 2 ...OK
=========> Step 3 ...OK
Phone Reset Done!
Waiting For Command ... Prepairing Method 3 ...
=========> Step 4 ...OK
=========> Step 5 ...OK
=========> Step 6 ...OK
=========> Step 7 ...OK
=========> Step 8 ...OK
=========> Step 9 ...OK
Phone Reset Done!
Operation Completed
Operation Time: 00:03:10
need asan help whats error i make it ?
