04-04-2019, 13:05 | #1 (permalink) |
Insane Poster Join Date: Dec 2015 Location: Sudan
Member: 2495537 Status: Offline Thanks Meter: 16 | add Board for TRT-TL10A |
04-05-2019, 01:22 | #2 (permalink) |
Member: 2495537 Status: Offline Thanks Meter: 16 | I managed to find a board firmware and fix this device very difficulty , a combination of Qfil hcu and sigma , used Qfil for repairing Qualcomm 9008 to bring fastboot ,used a tool to read IMEI and other info, and then used HCU to erase Oeminfo partition , although I could have done it manually , Oeminfo contains IMEI and vendor/country , might fail to flash the device in upgrade mode if you couldn't find the correct firmware , that was the case , that's why I had to erase Oeminfo , then used sigma to flash firmware based on the info I got just the phone model TRT-Tl10A in my case , any version should work because when Oeminfo is he/default after erasing you can flash whatever you want , one thing to notice if you flashed different model like TRT-L21 the screen will be black untill you flash the correct model that you got from fastboot before the Oeminfo initial erase , so be careful , it took me almost 2 days to figure all this out , I got the board in XML format from easy-firmeware , I have checked all the fourms and no success report , this is the first one I think , hope this helps someone else someday |
The Following 3 Users Say Thank You to awab228 For This Useful Post: |
04-07-2019, 11:57 | #3 (permalink) |
Member: 2495537 Status: Offline Thanks Meter: 16 | Here a more simple solution to the same problem after more testing , after using Qfile to revive boot into fastboot (screen may still be blank , because this device has some special thing relating the screen driver with the firmware), - use the command Code: - fastboot oem get-build-number (firmware info to download the correct one ) - fastboot getvar vendorcountry (country info) go to fastboot folder and flash this : **of course you need fastboot and adb installed ** Code: - fastboot flash partition gpt_both0.bin then Extract these files using Huawei update extractor , and flash them using fastboot Code: - fastboot flash recovery RECOVERY.img - fastboot flash erecovery ERECOVERY.img then enter upgrade more (both volume keys and plugin the usb) use sigma to flash the desired (correct firmware according to info) and the device should start normally . |
06-05-2019, 07:37 | #5 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ malka4u, What an issue phone originally had? What firmware version is originally had? What firmware was used for the flashing purposes? Also, post here full log files, from the performed operations. Best Regards GSMServer team |
06-05-2019, 10:20 | #6 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | mobile is in hang on logo state checked firmware version in fastboot mode (bootloader) TRT-L21AC185B181 OKAY [ 0.001s] vendorcountry: hw/meafnaf now flashed TRT-LX1 TRT-L21 hw meafnaf Toronto-L21AC185B175CUSTC185D001 Firmware 7.0.0 r1 EMUI5.1.3 05014MPA Code: SigmaKey 2.33.00 Qcom: Write firmware Android Adapter PCUI (COM139), Provider: Huawei Incorporated, Driver ver.: 2.0.6.714, Date: 12/28/2015, USB\Vid_12D1&Subclass_11&Prot_22 Firmware: TRT-L21AC185B150 Hardware IMEI: 020304050607080 Writing flash SHA256RSA OK Writing flash CRC OK Writing flash AMSS_VERLIST OK Writing flash PACKAGE_TYPE OK Writing flash GPT OK Writing flash RPM OK Writing flash TZ OK Writing flash SBL1 OK Writing flash APDP OK Writing flash MSADP OK Writing flash MODEM OK Writing flash AMSS_VER OK Writing flash DSP OK Writing flash CMNLIB OK Writing flash KEYMASTER OK Writing flash CMNLIB64 OK Writing flash MDTP OK Writing flash DEVCFG OK Writing flash LKSECAPP OK Writing flash ABOOT OK Writing flash RECOVERY OK Writing flash ERECOVERY OK Writing flash SYSTEM OK Writing flash CACHE OK Writing flash BOOT OK Writing flash VENDOR OK Writing flash PRODUCT OK File transferring.......update_TRT-L21A_hw_meafnaf.app Writing flash SHA256RSA OK Writing flash CRC OK Writing flash AMSS_VERLIST OK Writing flash PACKAGE_TYPE OK Writing flash AMSS_VER OK Writing flash CUST OK Writing flash VERSION OK Writing flash USERDATA OK Done |
06-05-2019, 13:25 | #8 (permalink) |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | now what is the solution???? goes to erecovery ok.download and install L21AC185B181 done still hang on logo any solution ? Last edited by malka4u; 06-05-2019 at 13:31. |
