10-30-2014, 11:37 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Watch this video and you will figure out how to find needed manuals by yourself. It's quite easy. |
10-30-2014, 15:18 | #3 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 335721 Status: Offline Thanks Meter: 12 | Connect SigmaBox / SigmaKey Dongle to PC USB port and launch SigmaKey Software Select "MTK" platform from the tab menu in the upper left side of the software Go to "IMEI" tab Connect* turned off phone to PC Select an appropriate COM port in SigmaKey Software (usually the highest number) Enter IMEI number in the "Phone IMEI" field ** Press "Restore IMEI" and follow the instructions in the log window Press and hold "Power ON" button on the phone As soon as SigmaKey Software shows an appropriate message in the log window, release "Power ON" button The message "Writing IMEI… OK" indicates that procedure was completed successfully Disconnect the handset * MTK models have to be connected to PC COM port via original COM data cable or any COM port emulator. If you are SigmaBox owner, connect phone to PC via SigmaBox. 5.which port (ı have a usb dongle) |
10-30-2014, 15:20 | #4 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ mehmet_iletişim, MT62xx based phone models requires to be connected to PC via COM port or any COM port emulator. In case you are SigmaKey dongle user you can use any COM port emulator in order to connect this phone model. Best Regards GSMServer team |
