09-11-2020, 22:21 | #1 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2386816 Status: Offline Sonork: 100.1664498 Thanks Meter: 0 | Motorola XT1756 repair IMEI done I've traid to repair imei of a Moto C device (XT1756) but I've got the following message: "You should activate required PACK to work with this model." I've tried using another computer and device but I didn't get good results, I got the same message. Do you know if a need another pack? or Can you help me to solve this problem? Thanks |
09-12-2020, 05:30 | #3 (permalink) |
Member: 2386816 Status: Offline Sonork: 100.1664498 Thanks Meter: 0 | For sure, these are the logs and the process I've done to get this error. Logs: SigmaKey v.2.39.00 717714352 Sigma dongle 2.39, Initializing...OK Pack 1: Activated Pack 2: Activated Pack 3: Not activated Pack 4: Not activated Pack 5: Not activated --------- 2020-09-12 01:24:19 --------- SigmaKey 2.39.00 MTK: Repair IMEI (Moto C (XT1756)) You should activate required PACK to work with this model. For more information visit sigmakey page Process to get the error: - Open SigmaKey program and go to the MTK platform - Go to the IMEI option - Serial Port: USB (autodetect) - Select any device, for example this Motorola Moto C XT1756 - Write imei - Click on Repair Imei |
09-12-2020, 05:54 | #4 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | YOU CAN TRY IN META MODE IF DIRECT FLASH MODE FAILED SEE THIS GUIDE ..(VIDEO) -Open Sigma go to mtk platform - Switch off mobile disconnect battery remove usb cable wait 10 second - Insert battery, insert usb cable wait until meta mode port appear in serial port - Go to the IMEI option - Serial Port: meta port - Fill imei - Click on Repair Imei |
09-12-2020, 16:08 | #7 (permalink) |
Member: 2386816 Status: Offline Sonork: 100.1664498 Thanks Meter: 0 | Thanks man. I could repair the imei following your steps. I have another question, do you know how I can use octopus as interface for sigma key? Thanks again. |
