09-11-2020, 07:39 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | BND-AL10 need guide how to unbrick.. Unit: BND - AL10 Problem: Your device has been unlocked and cant be trusted.. ( cant boot into upload mode/ erecovery mode) fone info: Code: Found Phone : BND-AL10 Model : Huawei phone in fastboot mode IMEI : 869574038024224 MEID : A000009184D75C Serial NR. : A5RNW18620000732 Firmware : BND-AL10C00B201 IMEI1:869574038043372 FB LockState: LOCKED USER LockState: UNLOCKED unlocked Battery state: 2466mv no luck.. |
09-11-2020, 07:56 | #2 (permalink) |
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Logs: Code: SigmaKey 2.38.06 HiSi: Write firmware HUAWEI USB COM 1.0 (COM5), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 65x Phone model: BND-AL10 Version: BND-AL10C00B201 Wrong selection of firmware files can damage the phone. Are you sure you want to proceed? [YES] Flash file C:\Users\Hayyan\Documents\BND-AL10C00B200\BND-AL10C00B200\update (1)\UPDATE.APP Phone model: BND-AL10 Version: BND-AL10C00B201 Writing flash xloader...OK Writing flash fw_lpm3...OK Writing flash fastboot...OK Writing flash modemnvm_update...OK Writing flash teeos...OK Writing flash trustfirmware...OK Writing flash sensorhub...OK Writing flash fw_hifi...OK Writing flash boot...failed to erase partition Writing flash recovery...failed to erase partition Writing flash recovery2...failed to erase partition Writing flash dts...OK Writing flash modem_fw...OK Writing flash cache.0...sparse flash write failure Writing flash system.0...OK Writing flash system.1...OK Writing flash system.2...OK Writing flash system.3...OK Writing flash system.4...OK Writing flash system.5...OK Writing flash vendor.0...OK Writing flash vendor.1...OK Writing flash product.0...OK Writing flash...Done Restarting phone...OK |
09-11-2020, 09:01 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Try Rescue mode entering, if this device can enter fastboot mode Last edited by mcandre; 09-11-2020 at 09:10. |
09-11-2020, 09:03 | #4 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 552 | chose other flash file, load fastboot flash stock, then reflash in upgrade mode https://androidhost.ru/6wn |
The Following User Says Thank You to kikas112 For This Useful Post: |
09-12-2020, 01:31 | #5 (permalink) | |
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Quote:
09-12-2020, 01:32 | #6 (permalink) | |
