07-23-2021, 10:59 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | ele-l29 frp remove done with Sigmakey HUAWEI USB COM 1.0 (COM98), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 06/11/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 Connecting........................................ .......................Failed how to solve this problem thx |
07-23-2021, 11:20 | #2 (permalink) |
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | SigmaKey 2.40.09b1 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 3.89 V Phone model: ELE-L29 Build number: ELE-L29 11.0.0.147(C431E8R2P3) Vendor/Country: hw/eea System version: Skipped Android version: 10 Base version: ELE-LGRP2-OVS 11.0.0.147 Custom version: ELE-L29-CUST 11.0.0.8(C431) Preload version: ELE-L29-PRELOAD 11.0.0.3(C431R2) Huawei-Over-the-Air info: C_version: C431 D_version: D000 PLMN: 20820 BoardID: 8553 DeviceName: ELE-L29 Done |
07-23-2021, 14:15 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ patric, Fully charge phone's battery, ensure that it is properly connected and repeat operation once again. In most cases such an issue appears due to battery. Best Regards GSMServer team |
04-17-2022, 09:39 | #11 (permalink) | |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,340 | Quote:
I recommend using hardware TP for your firmware version (ELE-L29 11.0.0.156). Most probably that you will have to use this method: How to service devices with closed (disabled) hardware TP | |
The Following User Says Thank You to Gsmserver For This Useful Post: |
04-17-2022, 09:52 | #12 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Punjab
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | here is complete info Android version: 10 Base version: ELE-LGRP2-OVS 11.0.0.156 Custom version: ELE-L29-CUST 11.0.0.4(C185) Preload version: ELE-L29-PRELOAD 11.0.0.3(C185R7) |
04-17-2022, 10:22 | #13 (permalink) |
Member: 21077 Status: Offline Thanks Meter: 116,340 | A slightly higher version required a modified cable. I think your version also requires disassembly of the phone + modified cable. |
