File I/O operation failed [SOLVED] I have seen this error many times, what does it mean? this time was unlocking Motorola EX116 from Telcel. thanks for your time |
can you show the log with this error? |
Sure Quote:
1611xxxx Sigma dongle 1.20, Initializing...OK SigmaKey 1.18.05 MTK: Direct unlock USB Serial Port (COM24), Provider: FTDI, Driver ver.: 2.6.0.0, Date: 10/22/2009 Baud rate: 19200 Release "Power on" button! Baseband Processor: MT6235, HW Rev. C.00, SW Rev. A.01 Serial number: 316C3168ED4687CD00000000AC2693C9 Testing external RAM...64 Mb Detecting flash...NAND, ID: 00AD00A1-00000015, manufacturer: Hynix Flash size: 128 Mb, page size: 2048 File system: 78 Mb @ 03200000 Firmware: A8256_WIFI_FB_PCB01_GPRS_MT6235B_S01.SQMINI_G_07_1 7_00RPS Hardware IMEI: 358976040358466 Mounting system disk...#1 File I/O operation failed this was with EX116 from Telcel. thanks |
@ BackSlash_cu, During unlock operation SigmaKey saves phone's Security area. According to provided log file there's no free space at your PC. Please clean some space and run unlock operation once again. Best Regards GSMServer team http://www.smart-clip.com/img/sigma_userbar.png |
A friend told me the solution for EX116 Telcel. Read Codes Enter ###765*08# using a valid SIM Card Enter the readed code. note: you only have one chance to enter the right code, take care |
BackSlash_cu, it seems like you have deleted some files and folders from your PC recently. http://sigmakey.com/nfs/content/5804...l_settings.png Go to SigmaKey tab, then check whether Security backup folder exist on your PC :) If it doesn't exist - just create it. And this case will be solved. |
Problem solved!! Quote:
THANKS pd: this must be on FAQ, :D |
MOTOROLA XT531: Which is the problem? http://s7.postimg.org/wqwbjo7ln/fdfdfdfdfdfdf.png I have 470 gb free space in my DD Many thanks |
Solved ;) Many Thanks |
Mine is not solved. There is a security backup, but still failure. |
@ kfortune, What an issue exactly you have? Did you check all of the folders that suppose to be in the My Documents\SigmaKey\... file folder? Best Regards GSMServer team http://www.smart-clip.com/img/sigma_userbar.png |
I had the same problem. Just plug TURNED OFF phone and chose Qualcomm Tab, there will be displayed DIAG port. |
--------- 2017-02-23 21:17:48 --------- SigmaKey 2.23.03 ADB: Enable diagnostic port * daemon not running. starting it now * * daemon started successfully * ^ Android Composite ADB Interface Version: Linux version 2.6.38.6-perf (android@localhost) (gcc version 4.4.3 (GCC) ) #1 PREEMPT Tue Aug 21 20:12:21 CST 2012 Phone model: HUAWEI U8185 Android 2.3.6; Firmware: HuaweiU8185; Date: Tue Aug 21 19:44:36 CST 2012 Version: U8185-1V100R001C00B837 Baseband Firmware: 109808 Baseband Processor: MSM7x27a U8185 BOARD Enabling diagnostic port...Done --------- 2017-02-23 21:18:49 --------- SigmaKey 2.23.03 Qcom: Direct unlock USB Serial Port (COM15), Provider: FTDI, Driver ver.: 2.12.24.0, Date: 9/28/2016, FTDIBUS\COMPORT&VID_0403&PID_0000 Missing response from phone --------- 2017-02-23 21:19:15 --------- SigmaKey 2.23.03 ADB: Direct unlock * daemon not running. starting it now * * daemon started successfully * ^ Android Composite ADB Interface Version: Linux version 2.6.38.6-perf (android@localhost) (gcc version 4.4.3 (GCC) ) #1 PREEMPT Tue Aug 21 20:12:21 CST 2012 Phone model: HUAWEI U8185 Android 2.3.6; Firmware: HuaweiU8185; Date: Tue Aug 21 19:44:36 CST 2012 Version: U8185-1V100R001C00B837 Baseband Firmware: 109808 Baseband Processor: MSM7x27a U8185 BOARD Version: U8185-1V100R001C00B837 Reading data...File I/O operation failed --------- 2017-02-23 21:22:01 --------- SigmaKey 2.23.03 ADB: Direct unlock * daemon not running. starting it now * * daemon started successfully * ^ Android Composite ADB Interface Version: Linux version 2.6.38.6-perf (android@localhost) (gcc version 4.4.3 (GCC) ) #1 PREEMPT Tue Aug 21 20:12:21 CST 2012 Phone model: HUAWEI U8185 Android 2.3.6; Firmware: HuaweiU8185; Date: Tue Aug 21 19:44:36 CST 2012 Version: U8185-1V100R001C00B837 Baseband Firmware: 109808 Baseband Processor: MSM7x27a U8185 BOARD Version: U8185-1V100R001C00B837 Reading data...File I/O operation failed what is this problem bro i tried every thing but same problem plezzzzzz |
Reading data...File I/O operation failed i also create security backup folder but same problem ??? plezzzzzzzz |
