04-06-2019, 20:45 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: SRI LANKA
Member: 1857049 Status: Offline Sonork: 100.1627774 Thanks Meter: 208 | How to unlock HWV32 hiawei p20 guide with sigmakey HWV32 AU P20 very easy to unlock with sigmakey....today i done 2 jobs no risk and easy to unlock just go to dial pad *#*#2846579#*#* - background settings- usb port-manufacture mode..in sigma key select hiselicon tab and find driver (pcui port driver) p20 drivers you can download sigmakey website..just direct unlock..done✅ If firmware not support oh latest patch level.then you must downgrade firmware to unlock support old firmware... But no worries..find support firmware on google oh i used easyfirmware.com Here i used firmware https://easy-firmware.com/index.php?...file&id=122785 After downloading and extract file. Please use 4GB oh higher fat32 formated. Copy extracted firmware(dload)folder to sd card and insert to phone..go to dial pad and dial*#*#2846579#*#* pop up menu- background settings-software update-sd card update Thats all phone will sart to downgrade..after that repeat 1st operations Go to dial pad dial *#*#2846579#*#* -background settings-usb port settings-manufacture mode- Connect to sigmakey and unlock ✅✅✅✅ |
The Following 6 Users Say Thank You to samindapowerson For This Useful Post: |
06-24-2019, 08:08 | #5 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ alex_030385, In case phone has latest security patch installed, it can not be unlocked without downgrading. Best Regards GSMServer team |
07-04-2019, 14:09 | #6 (permalink) |
Freak Poster Join Date: Sep 2010 Location: InsiDe lAtest CPUs Age: 35
Member: 1386000 Status: Offline Sonork: 100.1624055 Thanks Meter: 29 | Hi, HWV32 EMUI version 9.1.0 Android security patch June 5 2019 cannot downgrade. It says software install failed. Incompatible with current version.please download the correct package. |
The Following User Says Thank You to Ifhamgo7 For This Useful Post: |
