Reset FRP using this method Remove FRP for the NEWEST Huawei HiSilicon and Qualcomm smartphones Do everything according to the manual |
i get another eml l29 p20 not showing allow rsa option....i reinstalled the driver but rsa allow dont comup on screen... Quote:
hello sir The phone will ask to confirm RSA key fingerprint. If phone is not asking for RSA key fingerprint: Cancel the Remove FRP operation. Reboot the phone manually. reboot many time but not ask for rsa fingerprint. more suggestion plz |
king2050, what drivers do you use? Use drivers from Sigma manual - Remove FRP for the NEWEST Huawei HiSilicon and Qualcomm smartphones |
abidfarooq, what drivers do you use? Use drivers from Sigma manual - Remove FRP for the NEWEST Huawei HiSilicon and Qualcomm smartphones |
I used from sigma site.. Sent from my iPhone using Tapatalk |
HEY i used the same driver but still not showing allow button i reset the phone also...but still same using window 10.. |
To install the drivers for required phone follow this https://gsmserver.com/nfs/content/61...te10_driver.7z Select "Android ADB" platform from the tab menu in the upper left side of the software. Go to "HiSilicon" tab, if you have HiSilicon-based phone. Or go to Qualcomm tab, if your phone is Qualcomm-based. Turn the phone ON and connect it to PC with the USB cable. Select “Android ADB interface” port. Press “Remove FRP” button. The phone will ask to confirm RSA key fingerprint. If phone is not asking for RSA key fingerprint: Cancel the Remove FRP operation. Reboot the phone manually. Run the Remove FRP operation once again. The message "Removing FRP… Done" indicates that procedure has been completed successfully. Disconnect the phone. Reboot the phone. Perform Master Reset from the phone menu. |
use latest driver from support.but same problem |
on same phone adb option comesup on some phone allow option dont com up....easy to reset frp with hand...with box u have to fight...i open 3 phone with box but 2 phone was not showing allow option...i used the hand method... |
