06-12-2020, 17:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Germany Age: 54
Member: 11273 Status: Offline Thanks Meter: 14 | I need .skf file for Huawei P30 Pro VOG-L29 C431 I try to downgrade this Phone but I found in bootloader.com Huawei Downgrade Files just this file VOG-L09C_9.1.0_C431.skf can I use it with my phone VOG-L29 or do you have one for VOG-L29 without "C"?: SigmaKey 2.35.02 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.29 V Phone model: VOG-L29 Build number: VOG-L29 9.1.0.178(C431E4R2P2) Vendor/Country: hw/eea System version: Skipped Android version: 9 Base version: VOG-LGRP2-OVS 9.1.0.178 Custom version: VOG-L29-CUST 9.1.0.4(C431) Preload version: VOG-L29-PRELOAD 9.1.0.2(C431R2) Huawei-Over-the-Air info: C_version: C431 D_version: D000 PLMN: 26203 BoardID: 8542 DeviceName: VOG-L29 Done Best Regards |
06-16-2020, 13:02 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Read this manual: Android 9 and Android 8: Downgrade or change firmware operations |
06-17-2020, 18:17 | #5 (permalink) | |
Member: 11273 Status: Offline Thanks Meter: 14 | Quote:
1- You may use Remove FRP feature on Service tab, it reads the phone information from Fastboot mode. My phone is: Phone model: VOG-L29 Version: :VOG-L29 9.1.0.178(C431E4R2P2) 2- STEP 3: Prepare the downgrade *.skf file You can download the downgrade *.skf files from bootloader.com, free section -> Huawei -> Downgrade files, or here (installer with addons for all models). The chosen downgrade file has to: exactly fit your phone model and Android version be the SAME firmware version as is in the phone now be the same customization version this mean I need a downgrade file like: VOG-L29_9.1.0_C431.skf but in bootloader.com, free section -> Huawei -> Downgrade files I found just 2 files VOG-L09C_9.1.0_C431.skf and VOG-L29C_10.0.0_C431.skf. the both files do NOT much my phone My question: which *.skf file should I use to downgrade this mobile? Best regards | |
06-18-2020, 09:03 | #6 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | Use this SKF for downgrading: VOG-L09C_9.1.0_C431.skf Use suitable flash files, lover version. Last edited by mcandre; 06-18-2020 at 09:13. |
06-20-2020, 20:44 | #7 (permalink) | |
I did what you wrote but I get now VERSION MISMATCH error. I tried many SKFs but same result Here is my Log: SigmaKey 2.35.02 HiSi: Enable downgrade DBAdapter Reserved Interface (COM54), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18.05.2016, USB\Vid_12D1&Subclass_13&Prot_23 Enabling firmware downgrade...D:\Users\Sam\Downloads\Flashes\Huawei\ VOG-L29\VOG-L09C_9.1.0_C431.skf Hardware IMEI: 020304050607080 Flash file D:\Users\Sam\Downloads\Flashes\Huawei\VOG-L29\Huawei P30 Pro VOG-L29 hw eea VOGUE-L29C 9.1.0.115(C431E4R2P2) Firmware 9.0.0 r3 EMUI9.1.0 05015THE [androidhost.ru]\Software\dload\base\PTABLE.APP Writing flash SHA256RSA OK Writing flash CRC OK Writing flash BASE_VERLIST ...Version mismatch. Use "Enable downgrade" action first, then retry flashing. --------- 2020-06-20 20:50:08 --------- SigmaKey 2.35.02 HiSi: Enable downgrade DBAdapter Reserved Interface (COM54), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18.05.2016, USB\Vid_12D1&Subclass_13&Prot_23 Enabling firmware downgrade...D:\Users\Sam\Downloads\Flashes\Huawei\ VOG-L29\VOG-L09C_9.1.0_C431.skf Hardware IMEI: 020304050607080 Flash file D:\Users\Sam\Downloads\Flashes\Huawei\VOG-L29\Huawei P30 Pro VOG-L29 hw eea VOGUE-L29C 9.1.0.115(C431E4R2P2) Firmware 9.0.0 r3 EMUI9.1.0 05015THE [androidhost.ru]\Software\dload\base\PTABLE.APP Writing flash SHA256RSA OK Writing flash CRC OK Writing flash BASE_VERLIST ...Version mismatch. Use "Enable downgrade" action first, then retry flashing. --------- 2020-06-20 21:01:46 --------- SigmaKey 2.35.02 HiSi: Enable downgrade DBAdapter Reserved Interface (COM54), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18.05.2016, USB\Vid_12D1&Subclass_13&Prot_23 Enabling firmware downgrade...D:\Users\Sam\Downloads\Flashes\Huawei\ VOG-L29\VOG-L09C_9.1.0_C431.skf Connecting...Please send D:\Users\User\Documents\SigmaKey\temporary backup\0537388712\VOG 9_1_0(OVS).skb file to [email protected] Missing response from boot --------- 2020-06-20 21:03:31 --------- SigmaKey 2.35.02 HiSi: Enable downgrade DBAdapter Reserved Interface (COM54), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18.05.2016, USB\Vid_12D1&Subclass_13&Prot_23 Enabling firmware downgrade...D:\Users\Sam\Downloads\Flashes\Huawei\ VOG-L29\VOG-L09C_9.1.0_C431.skf Hardware IMEI: 020304050607080 Flash file D:\Users\Sam\Downloads\Flashes\Huawei\VOG-L29\base\PTABLE.APP Writing flash SHA256RSA OK Writing flash CRC OK Writing flash BASE_VERLIST ...Version mismatch. Use "Enable downgrade" action first, then retry flashing. SigmaKey 2.35.02 HiSi: Enable downgrade DBAdapter Reserved Interface (COM54), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18.05.2016, USB\Vid_12D1&Subclass_13&Prot_23 Enabling firmware downgrade...D:\Users\Sam\Downloads\Flashes\Huawei\ VOG-L29\VOG-L29C_9.1.0_C432.skf Hardware IMEI: 020304050607080 Flash file D:\Users\Sam\Downloads\Flashes\Huawei\VOG-L29\base\PTABLE.APP Writing flash SHA256RSA OK Writing flash CRC OK Writing flash BASE_VERLIST ...Version mismatch. Use "Enable downgrade" action first, then retry flashing. SigmaKey 2.35.02 HiSi: Enable downgrade DBAdapter Reserved Interface (COM54), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18.05.2016, USB\Vid_12D1&Subclass_13&Prot_23 Enabling firmware downgrade...D:\Users\Sam\Downloads\Flashes\Huawei\ VOG-L29\VOG-L29C_10.0.0_C431.skf Hardware IMEI: 020304050607080 Flash file D:\Users\Sam\Downloads\Flashes\Huawei\VOG-L29\base\PTABLE.APP Writing flash SHA256RSA OK Writing flash CRC OK Writing flash BASE_VERLIST ...Version mismatch. Use "Enable downgrade" action first, then retry flashing. | |
