02-20-2015, 05:36 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: baguio city philippines
Member: 981198 Status: Offline Sonork: 100.1602386 Thanks Meter: 131 | motorola wx345 successfully unlock but no srvice???????? imei begin 0123600........ i check in setting but no network setting to change because maybe this is set to 850/1900 and i need to change to 900/1800. is there other way or only convertion??????? |
The Following User Says Thank You to markrhoden For This Useful Post: |
02-20-2015, 07:13 | #2 (permalink) |
Member: 981198 Status: Offline Sonork: 100.1602386 Thanks Meter: 131 | ?????????????????? up my thread....................... |
02-20-2015, 08:59 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ markrhoden, For WX345 type: ***#3646633# Engineer mode activation. This menu allows to select network type you want the phone to work in. Also, according to the IMEI number, it may happen that this phone works with 850/1900 Mhz band settings only. Best Regards GSMServer team |
The Following 2 Users Say Thank You to GSM_Support For This Useful Post: |
02-21-2015, 09:08 | #4 (permalink) | |
Member: 981198 Status: Offline Sonork: 100.1602386 Thanks Meter: 131 | Quote:
this engineer mode not work for me.... | |
02-21-2015, 10:02 | #5 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1005456 Status: Offline Thanks Meter: 39 | Try mo nga yan Boss.. You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps: enter menu and press 048263* quickly, then you will enter the secret engineering menu under "Opcode" input 10*0*3 for GSM 900 10*0*4 for GSM 1800 10*0*5 for GSM 1900 10*0*6 for dual band GSM 900/1800 10*0*7 for dual band GSM 850/1900 |
The Following User Says Thank You to rievax For This Useful Post: |
02-21-2015, 11:38 | #6 (permalink) | |
i think this codes is for old motorola, i try but its not working | |
