04-04-2019, 06:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: uk
Member: 306676 Status: Offline Thanks Meter: 148 | Motorola XT1924-1 Reset FRP OK ,but now is NO NETWORK ! Set the phone to the FACTORY MODE: Turn the phone OFF Press Vol -, Vol+, Power ON simultaneously, then release Power ON button Select FACTORY MODE in the appeared menu, then confirm your selection Wait for the phone to fully power ON and connect it to PC Select "Adb interface" in the port selection tab Press "Remove FRP" button Message "Done" indicates that the procedure has been completed successfully Restart the phone . --------- 2019-04-04 08:21:27 --------- SigmaKey 2.30.03 ADB: Remove FRP * daemon not running. starting it now * * daemon started successfully * ^ Android Composite ADB Interface Phone model: motorola moto e5 plus Android 8.0.0; Firmware: OPPS27.91-179-2; Date: Thu Jan 17 04:10:59 CST 2019 Version: OPPS27.91-179-2 Baseband Firmware: M8917_26.30.05.75R HANNAH_EMEADSDS_CUST Removing FRP lock....Done ... but now is NO NETWORK ! |
04-04-2019, 08:44 | #2 (permalink) |
Member: 306676 Status: Offline Thanks Meter: 148 | Problem solved Let’s Remove Comserver and Solve Calling, Charging Issues: -Go to “Settings”, and then tap on “Apps”. -Tap on top right corner “3dots”, and then tap on “Show Systems Apps”. -Tap on “Force Stop”, after that tap on “Disable”. -Now tap on “Storage”, and then tap on “Clear Cache” and “Clear Data”. -Now tap on “Notification” and then tap on “Block All”. Reboot Moto Device into Recovery Mode to Remove Comserver: -Switch Off Moto Device. -Press & Hold “Power button + Volume Down Button” until you enter in “Recovery Mode“. -Press “Volume Down” key to get “Reboot Boatloader“. -Once you get “Reboot Bootloader“, after that press “Power Key” to select that boatloader. -Now you will get “START” option again, just press “Power Button” to select “Start”. Now you have successfully fixed “Charging Issue”, and also successfully get rid of “Popup Notification” of “Comserver Has Started”. Everything is fine now ! |
08-04-2019, 22:16 | #3 (permalink) | |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Quote:
How to make this solution permanent???...If I reboot the phone it has no network, I have to repeat the last step to turn off airplane mode (enter recovery, rebot bootloader and start) it's not a big deal bit the client wants the phone to be ok | |
08-04-2019, 23:08 | #4 (permalink) | |
Freak Poster Join Date: Feb 2017 Location: D.R
Member: 2684440 Status: Offline Thanks Meter: 218 | Quote:
Put the phone on fastboot mode CMD and type this fastboot oem fb_mode_set fastboot -w fastboot oem fb_mode_clear fastboot reboot And enjoy Sent from my moto e5 ***** using Tapatalk | |
The Following 6 Users Say Thank You to GSM_FIX For This Useful Post: |
