11-15-2014, 23:18 | #1 (permalink) |
Crazy Poster Join Date: Mar 2013 Location: República Dominicana
Member: 1899064 Status: Offline Thanks Meter: 4 | necesito ayuda con sigmakey todo bien hay, al conectarlo sin la sigma box el controlador aparece perfecto: Android sooner Single ADB Interface. pero al conectar el móvil a la sigma box aparece lo mismo pero con un triangulo amarillo osea que el controlador no se instalo correctamente, e buscado alguna solución pero no e logrado resolver el problema si alguien pudiera ayudarme estaría agradecido. |
11-16-2014, 00:54 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | You have here the information for unlock your Phone: You need put phone in Fastboot Mode. http://forum.gsmhosting.com/vbb/f719...nlock-1657367/ Hermano! en esto enlace tiens la informacion para lo Liberares con la Sigma.Tienes que colocar lo Telefono en Fastboot Mode. Saludos Regards |
The Following User Says Thank You to Haicha For This Useful Post: |
11-17-2014, 21:11 | #4 (permalink) |
Member: 1899064 Status: Offline Thanks Meter: 4 | hello, and attempted to perform an unlock huawei U8651T ADB INTERFACE by performing the following operation: precionar volume down more power button until it locks the logo on T-MOBILE. all right there, to connect without driver sigma box appears perfect: Single ADB Interface Android sooner. but when you connect the phone to the sigma box appears the same but with a yellow triangle I mean that the driver is not installed correctly, and sought a solution but not able to resolve the problem and if someone could help I would be grateful. |
11-17-2014, 21:25 | #5 (permalink) |
Member: 1899064 Status: Offline Thanks Meter: 4 | friend's problem is that when I connect to the box in fastboot mode and go device manager the driver with a yellow triangle, I mean that is not installed correctly. if I connect if the direct box to the PC conrolador okay, apparently the proble is the case. I need help please. |
11-17-2014, 23:43 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | Quote:
good luck mfeliu07 | |
The Following User Says Thank You to mfeliu07 For This Useful Post: |
11-18-2014, 08:41 | #8 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ girbel, Why you connect phone to SigmaBox? Reconnect phone to PC USB port in a FastBoot / Download mode and repeat Direct Unlock operation according to this manual. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
11-18-2014, 21:12 | #10 (permalink) | |
Member: 1899064 Status: Offline Thanks Meter: 4 | Quote:
the problem is connected to the PC controller is fine but when connected to the box appears as if it would be installed. | |
11-19-2014, 08:09 | #11 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ girbel, Please make a photo of how you connect phone to PC, screenshot of the device manager and post it here. Below you can find Video tutorial on the unlock operation of this phone: Best Regards GSMServer team |
