11-11-2020, 12:41 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Punjab
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | P40 Lite JNY-LX1 Huawei ID i have P40 Lite JNY-LX1 on HUAWEI ID Is it same procedure like FRP remove on test point method with same firmware of phone? Thanks |
The Following User Says Thank You to darmobiles For This Useful Post: |
11-12-2020, 12:29 | #3 (permalink) |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | System version: Skipped Android version: 10 Base version: JNY-LGRP2-OVS 10.1.0.245 Custom version: JNY-L21-CUST 10.1.0.3(C185) Preload version: JNY-L21-PRELOAD 10.0.1.1(C185R2) Huawei-Over-the-Air info: C_version: C185 D_version: D000 PLMN: 41001 BoardID: 1940 DeviceName: JNY-L21 Done SigmaKey 2.39.04 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM1799), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.24.0, Date: 12/18/2015, USB\Vid_12D1&Subclass_13&Prot_23 Using extended heuristic method... Hardware IMEI: 020304050607080 Flash file C:\Users\DELL\Desktop\Huawei P40 lite (Nova 7i) JNY-LX1 JNY-L21 hw meafnaf Jenny-L21A 10.1.0.245(C185E3R6P1) Firmware EMUI10.1.0 05016NTA [androidhost.ru]\Software\dload\UPDATE.APP Please send C:\Users\DELL\Documents\SigmaKey\temporary backup\0514223872\Jenny-LGRP2-OVS 10_0_1_100 (1).skb file to [email protected] Data retention error |
11-12-2020, 13:02 | #4 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ darmobiles, Current case has been transferred to developers team for an analyzing purposes. For the test purposes perform following steps:
Best Regards GSMServer team |
The Following 2 Users Say Thank You to GSM_Support For This Useful Post: |
11-12-2020, 13:59 | #5 (permalink) | |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | Quote:
12-28-2020, 15:07 | #7 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ darmobiles, Yes, you can try servicing phone. If "Data retention error" more likely that the phone has latest securoty patches are installed. In such case, you can try servicing phone via hardware testpoint operation. After that post results in a current thread. Best Regards GSMServer team |
01-20-2021, 12:47 | #8 (permalink) |
Junior Member Join Date: Sep 2015 Location: iran
Member: 2466134 Status: Offline Sonork: ahmednemat Thanks Meter: 3 | --------- 2021-01-20 15:16:40 --------- SigmaKey 2.39.08 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM42), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 5/18/2016, USB\Vid_12D1&Subclass_13&Prot_23 Using extended heuristic method... Hardware IMEI: 020304050607080 Flash file C:\Users\MATRIX\Desktop\downloads\Jenny-L21A 10.1.0.245(C185E3R6P1) Firmware EMUI10.1.0 05016NTA\Software\dload\UPDATE.APP Please send C:\Users\MATRIX\Documents\SigmaKey\temporary backup\0497527032\Jenny-LGRP2-OVS 10_0_1_100 (2).skb file to [email protected] Data retention error |
01-20-2021, 12:48 | #9 (permalink) |
Member: 2466134 Status: Offline Sonork: ahmednemat Thanks Meter: 3 | P40 Lite JNY-LX1 Huawei ID --------- 2021-01-20 15:16:40 --------- SigmaKey 2.39.08 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM42), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 5/18/2016, USB\Vid_12D1&Subclass_13&Prot_23 Using extended heuristic method... Hardware IMEI: 020304050607080 Flash file C:\Users\MATRIX\Desktop\downloads\Jenny-L21A 10.1.0.245(C185E3R6P1) Firmware EMUI10.1.0 05016NTA\Software\dload\UPDATE.APP Please send C:\Users\MATRIX\Documents\SigmaKey\temporary backup\0497527032\Jenny-LGRP2-OVS 10_0_1_100 (2).skb file to [email protected] Data retention error |
01-20-2021, 13:34 | #10 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ ahmednemat, Ensure that you are using correct/suitable firmware version, it is recommended to use same firmware as the phone has or higher one, after that repeat operation according to the manual once again. If "Data retention error" still appears, more likely that the phone has latest security patches are installed. In such case, you can try servicing phone via hardware testpoint operation. After that post results in a current thread. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
01-21-2021, 11:45 | #11 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Can't remove Huawei ID on this phone (P40lite JNY-l21) SigmaKey v.2.39.08 xxxxxxxxxx Sigma dongle 2.39, Initializing...OK Pack 1: Activated Pack 2: Activated Pack 3: Activated Pack 4: Activated Pack 5: Not activated --------- 2021-01-21 12:35:51 --------- SigmaKey 2.39.08 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM29), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 810 Phone model: JNY-LX1 Version: JNY-L21 10.1.0.261(C432E1R6P1) Removing firmware protection.....Failed --------- 2021-01-21 12:37:54 --------- SigmaKey 2.39.08 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM29), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 810 Phone model: JNY-LX1 Version: JNY-L21 10.1.0.261(C432E1R6P1) Removing firmware protection.....Failed --------- 2021-01-21 12:43:04 --------- SigmaKey 2.39.08 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM29), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 810 Phone model: JNY-LX1 Version: JNY-L21 10.1.0.261(C432E1R6P1) Removing firmware protection.....Failed |
01-21-2021, 11:48 | #12 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,340 | dragosgsm, Battery must be connected to the phone's board and fully charged. Especially while performing operations using testpoint. |
The Following 2 Users Say Thank You to Gsmserver For This Useful Post: |
01-21-2021, 12:40 | #13 (permalink) |
Member: 2466134 Status: Offline Sonork: ahmednemat Thanks Meter: 3 | --------- 2021-01-21 14:15:29 --------- SigmaKey 2.39.08 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM58), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 8/10/2014, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 810 Phone model: JNY-LX1 Version: JNY-L21 10.1.0.245(C185E3R6P1) Removing FRP lock...Done Removing Huawei ID....Done |
01-25-2021, 12:32 | #14 (permalink) |
Freak Poster Join Date: Jun 2013 Location: south Africa
Member: 1960717 Status: Offline Sonork: 100.1638403 Thanks Meter: 34 | jny-lx1 frp unlocked with sigma SigmaKey 2.39.08b1 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM85), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 8/9/2014, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 810 Phone model: JNY-LX1 Version: JNY-L21 10.1.0.226(C185E3R4P1) Removing firmware protection.....Failed |
01-25-2021, 12:49 | #15 (permalink) |
Member: 21077 Status: Offline Thanks Meter: 116,340 | ali_GSM98, Battery must be connected to the phone's board and fully charged. Especially while performing operations using testpoint. |
The Following User Says Thank You to Gsmserver For This Useful Post: |
