03-24-2023, 07:46 | #1 (permalink) | ||
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | P40 Pro - Huawei ID Huawei P40 Pro hw eu ELS-NX9 Elsa-N29 ELS-N29 ELS-N29 11.0.0.230(C432E3R6P4) DONE: Quote:
Read this post and Try: https://forum.gsmhosting.com/vbb/f71...olved-3042467/ SAme ISSUE What can be DONE? ONly BOOT KIRIN 990 5g WOrks Quote:
03-24-2023, 09:30 | #2 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,340 | Don't forget to connect charged battery to the board during the service operation. Connect usb cable to the USB port from the motherboard side. Disconnect and restart the device. Connect the device in COM 1.0 mode, don't perform "Load fastboot" Select P40/P40Pro 5G (boot 2) Start the Huawei ID operation from the beginning. |
03-24-2023, 09:46 | #3 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | Hello when choosing this: Select P40/P40Pro 5G (boot 2) When ask to change cable and use NORMAL usb.. it detects the USB but when it start the process it Restart the phone ! But his BOOT: KIRIN 990 5g does not Disconct the USB.. i tried manytimes ! |
03-24-2023, 12:40 | #5 (permalink) | |
Member: 64823 Status: Offline Thanks Meter: 439 | Quote:
If i choose KIRIN 990 5g the process is Completed sucessfully but it is still lock. THe disconnection only occurs when this boot: P40/P40Pro 5G (boot 2) | |
03-25-2023, 14:15 | #6 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: United Kingdom
Member: 1638915 Status: Offline Thanks Meter: 432 | Quote:
i follow this post i just done one same happen i had same issu 1st flash phone https://androidhost.ru/Z6c?pt=U2xsRE...SW5Vc2taZz0%3D after cleck 5g boot 2 removed id agin SigmaKey v.2.46.01 952276333 Sigma dongle 2.46, Initializing...OK Pack 1: Activated Pack 2: Activated Pack 3: Activated Pack 4: Activated Pack 5: Activated --------- 2023-03-25 11:39:25 --------- SigmaKey 2.46.01 HiSi: Enable downgrade HUAWEI USB COM 1.0 (COM35), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 Cancelled --------- 2023-03-25 11:39:38 --------- SigmaKey 2.46.01 HiSi: Enable downgrade HUAWEI USB COM 1.0 (COM35), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 990 5G Phone model: ELS-NX9 Version: ELS-N29 11.0.0.260(C432E3R5P3) Enabling firmware downgrade...Done --------- 2023-03-25 11:45:50 --------- SigmaKey 2.46.01 HiSi: Write firmware Wrong selection of firmware files can damage the phone. Are you sure you want to proceed? [YES] Flash file D:\MOBILE EXPERT\Huawei\P40pro\update sd bace\PTABLE.APP Phone model: ELS-NX9 Version: ELS-N29 11.0.0.260(C432E3R5P3) Writing flash ptable...OK Writing flash...Done Flash file D:\MOBILE EXPERT\Huawei\P40pro\update_sd_cust\PTABLE.APP Writing flash...Skipped Flash file D:\MOBILE EXPERT\Huawei\P40pro\update_sd_preload\PTABLE.APP Writing flash...Skipped Flash file D:\MOBILE EXPERT\Huawei\P40pro\update sd bace\UPDATE.APP Writing flash ptable...OK Writing flash xloader...OK Writing flash fastboot...OK Writing flash bl2...OK Writing flash boot...OK Writing flash dtbo...OK Writing flash vector...OK Writing flash fw_lpm3...OK Writing flash hhee...OK Writing flash vbmeta...OK Writing flash teeos...OK Writing flash trustfirmware...OK Writing flash hieps...OK Writing flash sensorhub...OK Writing flash fw_hifi...OK Writing flash modemnvm_update...OK Writing flash modemnvm_cust...OK Writing flash modem_driver...OK Writing flash recovery...OK Writing flash recovery_ramdisk...OK Writing flash recovery_vendor...OK Writing flash recovery_vbmeta...OK Writing flash erecovery...OK Writing flash erecovery_ramdisk...OK Writing flash erecovery_vendor...OK Writing flash erecovery_vbmeta...OK Writing flash preas.0...OK Writing flash preavs.0...OK Writing flash eng_vendor...OK Writing flash eng_system...OK Writing flash hdcp...OK Writing flash cache.0...OK Writing flash ramdisk...OK Writing flash super.0...OK Writing flash super.1...OK Writing flash super.2...OK Writing flash super.3...OK Writing flash super.4...OK Writing flash super.5...OK Writing flash super.6...OK Writing flash super.7...OK Writing flash super.8...OK Writing flash super.9...OK Writing flash super.10...OK Writing flash super.11...OK Writing flash metadata...OK Writing flash vbmeta_system...OK Writing flash vbmeta_vendor...OK Writing flash vbmeta_odm...OK Writing flash vbmeta_hw_product...OK Writing flash vbmeta_cust...OK Writing flash isp_firmware...OK Writing flash modem_fw...OK Writing flash ivp...OK Writing flash npu...OK Writing flash hisee_img...OK Writing flash userdata.0...OK Writing flash version.0...OK Writing flash preload.0...OK Writing flash patch.0...OK Writing flash kpatch...OK Writing flash...Done Flash file D:\MOBILE EXPERT\Huawei\P40pro\update_sd_cust\UPDATE.APP Writing flash version.0...OK Writing flash...Done Flash file D:\MOBILE EXPERT\Huawei\P40pro\update_sd_preload\UPDATE.APP Writing flash preload.0...OK Writing flash preload.1...OK Writing flash...Done --------- 2023-03-25 11:56:46 --------- SigmaKey 2.46.01 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM35), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: Kirin 990 5G Phone model: ELS-NX9 Version: ELS-N29 11.0.0.202(C432E3R6P4) SN: K5J0220526001413 OEM Info IMEI1: 862849040622125 OEM Info IMEI2: 862849040631126 MEID: A00000B80168C4 Phone model: ELS-NX9 Build number: ELS-N29 11.0.0.202(C432E3R6P4) Security area saved to "C:\Users\Mobile Expert\Documents\SigmaKey\security backup\0952276333\862849040622125_862849040631126_ Huawei_ELS-NX9_ELS-N29 11_0_0_202(C432E3R6P4).skb" Removing Huawei ID...Done --------- 2023-03-25 12:21:52 --------- SigmaKey 2.46.01 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM35), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: P40/P40Pro 5G (boot 3) Connecting........................................ .......................Failed --------- 2023-03-25 12:25:33 --------- SigmaKey 2.46.01 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM35), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: P40/P40Pro 5G (boot 3) Phone model: ELS-NX9 Version: ELS-N29 11.0.0.202(C432E3R6P4) SN: K5J0220526001413 OEM Info IMEI1: 862849040622125 OEM Info IMEI2: 862849040631126 MEID: A00000B80168C4 Phone model: ELS-NX9 Build number: ELS-N29 11.0.0.202(C432E3R6P4) The recommended bootloader version for this model: (boot 2) Security area saved to "C:\Users\Mobile Expert\Documents\SigmaKey\security backup\0952276333\862849040622125_862849040631126_ Huawei_ELS-NX9_ELS-N29 11_0_0_202(C432E3R6P4) (0).skb" Removing Huawei ID...Done --------- 2023-03-25 12:38:43 --------- SigmaKey 2.46.01 HiSi: Enable downgrade HUAWEI USB COM 1.0 (COM35), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: P40/P40Pro 5G (boot 2) Phone model: ELS-NX9 Version: ELS-N29 11.0.0.202(C432E3R6P4) Enabling firmware downgrade...Done --------- 2023-03-25 12:42:03 --------- SigmaKey 2.46.01 HiSi: Write firmware Wrong selection of firmware files can damage the phone. Are you sure you want to proceed? [YES] Flash file D:\MOBILE EXPERT\Huawei\P40pro\update sd bace\PTABLE.APP Phone model: ELS-NX9 Version: ELS-N29 11.0.0.202(C432E3R6P4) Writing flash ptable...OK Writing flash...Done Flash file D:\MOBILE EXPERT\Huawei\P40pro\update_sd_cust\PTABLE.APP Writing flash...Skipped Flash file D:\MOBILE EXPERT\Huawei\P40pro\update_sd_preload\PTABLE.APP Writing flash...Skipped Flash file D:\MOBILE EXPERT\Huawei\P40pro\update sd bace\UPDATE.APP Writing flash ptable...OK Writing flash xloader...OK Writing flash fastboot...OK Writing flash bl2...OK Writing flash boot...OK Writing flash dtbo...OK Writing flash vector...OK Writing flash fw_lpm3...OK Writing flash hhee...OK Writing flash vbmeta...OK Writing flash teeos...OK Writing flash trustfirmware...OK Writing flash hieps...OK Writing flash sensorhub...OK Writing flash fw_hifi...OK Writing flash modemnvm_update...OK Writing flash modemnvm_cust...OK Writing flash modem_driver...OK Writing flash recovery...OK Writing flash recovery_ramdisk...OK Writing flash recovery_vendor...OK Writing flash recovery_vbmeta...OK Writing flash erecovery...OK Writing flash erecovery_ramdisk...OK Writing flash erecovery_vendor...OK Writing flash erecovery_vbmeta...OK Writing flash preas.0...OK Writing flash preavs.0...OK Writing flash eng_vendor...OK Writing flash eng_system...OK Writing flash hdcp...OK Writing flash cache.0...OK Writing flash ramdisk...OK Writing flash super.0...OK Writing flash super.1...OK Writing flash super.2...OK Writing flash super.3...OK Writing flash super.4...OK Writing flash super.5...OK Writing flash super.6...OK Writing flash super.7...OK Writing flash super.8...OK Writing flash super.9...OK Writing flash super.10...OK Writing flash super.11...OK Writing flash metadata...OK Writing flash vbmeta_system...OK Writing flash vbmeta_vendor...OK Writing flash vbmeta_odm...OK Writing flash vbmeta_hw_product...OK Writing flash vbmeta_cust...OK Writing flash isp_firmware...OK Writing flash modem_fw...OK Writing flash ivp...OK Writing flash npu...OK Writing flash hisee_img...OK Writing flash userdata.0...OK Writing flash version.0...OK Writing flash preload.0...OK Writing flash patch.0...OK Writing flash kpatch...OK Writing flash...Done Flash file D:\MOBILE EXPERT\Huawei\P40pro\update_sd_cust\UPDATE.APP Writing flash version.0...OK Writing flash...Done Flash file D:\MOBILE EXPERT\Huawei\P40pro\update_sd_preload\UPDATE.APP Writing flash preload.0...OK Writing flash preload.1...OK Writing flash...Done --------- 2023-03-25 13:00:04 --------- SigmaKey 2.46.01 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM35), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: P40/P40Pro 5G (boot 2) Phone model: ELS-NX9 Version: ELS-N29 11.0.0.230(C432E3R6P4) SN: K5J0220526001413 OEM Info IMEI1: 862849040622125 OEM Info IMEI2: 862849040631126 MEID: A00000B80168C4 Phone model: ELS-NX9 Build number: ELS-N29 11.0.0.230(C432E3R6P4) Security area saved to "C:\Users\Mobile Expert\Documents\SigmaKey\security backup\0952276333\862849040622125_862849040631126_ Huawei_ELS-NX9_ELS-N29 11_0_0_230(C432E3R6P4).skb" Removing Huawei ID...Done try this firmware | |
