08-10-2020, 09:08 | #77 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ liuyinxin, Please explain in more details what an issue exactly you are dealing with. Make a new thread and post log files from the operations you are trying to perform. Best Regards GSMServer team |
08-11-2020, 06:26 | #79 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | This function is already there software test point on/ off But what I don't like about it is after rest Frp/Huawei ID Phone goes back to com1. 0 and to remove it again needs sending boot, removing software protection And most cases it gives error saying wait in 564******* secs so annoying. Need to retry before it can work |
The Following User Says Thank You to okello For This Useful Post: |
08-11-2020, 09:21 | #80 (permalink) |
Insane Poster Join Date: May 2018
Member: 2841001 Status: Offline Thanks Meter: 22 | I personally want to appreciate sigma for their works. I discovered tecno camon 11 and sa1 pro model selection actually service major infinix and tecno secure boot devices that are not added on the list. I want sigma team to add the new infinix note 7 models to complete the support of the secure boots. Thanks Sent from my SM-A730F using Tapatalk |
08-12-2020, 06:46 | #83 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ MR SALAUDDIN, At the moment, Kirin 710 based phone models are not supported for IMEI repair operation, wait for future releases. Best Regards GSMServer team |
08-12-2020, 14:20 | #84 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Huawei Mate 20 latest 10.1.0.270 service - FRP and OEM This phone can't be downgraded to any 10.0.x.xxx or earlier version (without to open it) - do not tested only with MRToKey. SigmaKey itself cannot downgrade it [HMA-L09CA_10.0.0_C432.skf is incompatible] also. I wasn't find a full flash HMA-L29 10.1.0.270(C432E8R1P5) and use via easy-firmware_dot_com 10.1.0.273(C185E5R2P4) to extract the main version update.app. In fact - it's working [ fast SW testpoint / enable diagnostic mode / unlocked Bootloader ] using it and go back to working phone: Code: --------- 2020-08-12 16:01:11 --------- SigmaKey 2.38.04b1 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM121), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18.5.2016 ã., USB\Vid_12D1&Subclass_13&Prot_23 Using extended heuristic method... Hardware IMEI: 020304050607080 Flash file ...\Huawei\HMA-L29\Hima-L29C 10.1.0.273(C185E5R2P4)_Firmware_EMUI10.1.0_05015KJU\Software\dload\UPDATE.APP Enabling diagnostic port...Done We strictly recommend performing "Enable Downgrade" on "Flash" tab, as the first service operation on this device! --------- 2020-08-12 16:02:03 --------- SigmaKey 2.38.04b1 HiSi: Read OEM Info... HUAWEI USB COM 1.0 (COM44), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 8.4.2015 ã., USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 Phone model: HMA-L29 Version: HMA-L29 10.1.0.270(C432E8R1P5) SN: MUN02189280xxxx7 IMEI1: 8694250315xxxx2 IMEI2: 8694250315xxxx2 MEID: A000009B2CF341 Phone model: HMA-L29 Build number: HMA-L29 10.1.0.270(C432E8R1P5) Reading data...Done --------- 2020-08-12 16:03:59 --------- SigmaKey 2.38.04b1 HiSi: Get device info SN: MUN02189280xxxx7 IMEI1: 8694250315xxxx2 IMEI2: 8694250315xxxx2 MEID: A000009B2CF341 Bootloader unlocked: YES FB unlocked: YES Battery voltage: - Phone model: HMA-L29 Build number: HMA-L29 10.1.0.270(C432E8R1P5) Vendor/Country: hw/eu System version: Skipped Android version: 10 Base version: HMA-LGRP2-OVS 10.1.0.270 Custom version: HMA-L29-CUST 10.0.0.8(C432) Preload version: HMA-L29-PRELOAD 10.0.0.5(C432R1) Huawei-Over-the-Air info: C_version: C432 D_version: D000 PLMN: 28405 BoardID: 8413 DeviceName: HMA-L29 Done --------- 2020-08-12 16:04:15 --------- SigmaKey 2.38.04b1 HiSi: Remove FRP / Huawei ID Phone model: HMA-L29 Version: HMA-L29 10.1.0.270(C432E8R1P5) Removing Huawei ID....Done Removing FRP lock...Done Restarting phone...OK --------- 2020-08-12 16:04:50 --------- SigmaKey 2.38.04b1 HiSi: Software testpoint On.../Off HUAWEI USB COM 1.0 (COM44), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 8.4.2015 ã., USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 Phone model: HMA-L29 Version: HMA-L29 10.1.0.270(C432E8R1P5) Using extended heuristic method... This operation may brick the phone if the phone firmware version does not EXACTLY match the software testpoint firmware version! If you are unsure, better completely reflash the firmware. Are you sure you want to proceed? [YES] Repairing.........Done WBR, DebeliaMark, BG |
08-12-2020, 16:18 | #85 (permalink) |
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | please help i always get this error on many phones and to work i have to reflash the phone SigmaKey 2.38.04 HiSi: Software testpoint On.../Off HUAWEI USB COM 1.0 (COM88), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 28/11/2016, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 710 Phone model: MAR-LX1M Version: MAR-L21MEA 10.0.0.237(C185E3R2P4) Removing firmware protection.....Wait 851026987 seconds and retry --------- 2020-08-12 18:13:20 --------- SigmaKey 2.38.04 HiSi: Software testpoint On.../Off HUAWEI USB COM 1.0 (COM88), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 28/11/2016, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 710 Phone model: MAR-LX1M Version: MAR-L21MEA 10.0.0.237(C185E3R2P4) Verifying....Not found |
08-13-2020, 16:13 | #86 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ okello, Provide us with full information on an issue you are dealing with. Make a separate thread and post full details and all log files from an operations you have performed to it. Best Regards GSMServer team |
08-13-2020, 19:38 | #87 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1211913 Status: Offline Thanks Meter: 423 | @gsm_support & team ❌Wait 851026987 seconds and retry ❌Verifying....Not found ❌ Send boot error [when try to s/w testpoint off 990 5g] And many of fails s/w testpoint off function after entering factory mode Lot of users fail these bugs. Please try to fix this |
08-13-2020, 19:51 | #88 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,340 | Thanks for all the logs and detailed problem descriptions. Of course, they are all analyzed and the program will be improved in the coming updates. |
