05-05-2020, 00:24 | #1 (permalink) |
Freak Poster Join Date: May 2014
Member: 2194348 Status: Offline Thanks Meter: 52 | Sne-lx1 10.0.0.176(c109e5r1p1) any solution Hi i have 2 sets of sne lx1 not supporting reset on recovery , and as i see there is no firmware for lx1 C109 , can i use any other firmware for sne-lx1 c432 |
05-05-2020, 08:23 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ beg-one, What operation exactly you want to perform? Do you want to downgrade phone's Android version? Please explain in more details. Best Regards GSMServer team |
05-06-2020, 00:15 | #4 (permalink) | |
Member: 2194348 Status: Offline Thanks Meter: 52 | Quote:
plz share a working firmware , i can only find the ota files wish i didnt managed to flash with sigma( the downgrade operation needs 6 files , and there is less in the ota full .... ) or sd card ... thnx | |
05-06-2020, 08:35 | #5 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,346 | Tell us what version you want to downgrade to. What flash file you want to use? Post the link here |
The Following User Says Thank You to Gsmserver For This Useful Post: |
05-09-2020, 14:05 | #6 (permalink) | |
Hi i have 2 sets of sne lx1 not supporting reset on recovery , and as i see there is no firmware for lx1 C109 grosso modo needflash file for reset the password and frp baypass | |
05-12-2020, 11:53 | #7 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ beg-one, Try any other available downgrade file for Android 10 + suitable flash file for downgrade (3 ptable.app + 3 update.app files) Best Regards GSMServer team |
05-12-2020, 18:25 | #8 (permalink) |
No Life Poster Join Date: Jun 2015 Location: the planet earth
Member: 2406539 Status: Offline Thanks Meter: 101 | SigmaKey 2.35.01 HiSi: Get device info Phone model: SNE-LX1 Build number: SNE-LX1 8.2.0.132(C782) Vendor/Country: O2/UK System version: SNE-LX1 8.2.0.132(C782CUSTC782D1) Android version: 8.1.0 Base version: Skipped Custom version: Skipped Preload version: Huawei-Over-the-Air info: C_version: C782 D_version: D1 PLMN: 23438 FirmWare: SNE-LX1 8.2.0.132(C782CUSTC782D1) DeviceName: SNE-L01 Done Huawei mate 20 lite, only showing red light blinking on top, screen is always blank, only showing fastboot devices info, not connecting to upgrade mode, any solution..? |
The Following User Says Thank You to TMAC1122 For This Useful Post: |
05-12-2020, 18:26 | #9 (permalink) |
Member: 2406539 Status: Offline Thanks Meter: 101 | can't check "authorize" button in flash tab, it's grey out, can't select it. SigmaKey 2.35.01 HiSi: Write firmware Wrong selection of firmware files can damage the phone. Are you sure you want to proceed? [YES] Flash file C:\Users\Desktop\sne-lx1\version 10\Software\dload\update_sd_base\PTABLE.APP Phone model: SNE-LX1 Version: :SNE-LX1 8.2.0.132(C782) Writing flash ptable...Command not allowed Writing flash...Done Flash file C:\Users\Desktop\sne-lx1\version 10\Software\dload\update_sd_cust_SNE-L01_hw_eu\PTABLE.APP Writing flash...Done Flash file C:\Users\Desktop\sne-lx1\version 10\Software\dload\update_sd_preload_SNE-L01_hw_eu_R1\PTABLE.APP Writing flash...Done Flash file C:\Users\Desktop\sne-lx1\version 10\Software\dload\update_sd_base\UPDATE.APP Writing flash ptable...Internal error 6666 Disconnect SigmaKey/Box...OK |
05-12-2020, 18:47 | #10 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Bucharest-Romania Age: 51
Member: 14200 Status: Offline Sonork: Sonork id Thanks Meter: 117 | Serch for firmware here: https://androidhost.ru/search.html you need to be carefull and flash right firmware you have. you can't flash Sne-lx1 10.0.0.176(c109e5r1p1) with C342. your phone will be dead. you need to find lower firmware with C109. and if your phone don't enter in upgrade mode, disassembly your phone and flash your phone with testpoint. read manual very carefull. use manual Android 10 / UFS phones: Downgrade / Change firmware operation. And select all 7 files. i spend some day too but i understand how to doungrade huawei firmware. i succes downgrade P30 lite. You need to select 7 files: FLASH FILE 1: PTABLE.APP from update_sd_base folder FLASH FILE 2: PTABLE.APP from update_sd_cust folder FLASH FILE 3: PTABLE.APP from update_sd_preload folder FLASH FILE 4: UPDATE.APP from update_sd_base folder FLASH FILE 5: UPDATE.APP from update_sd_cust folder FLASH FILE 6: UPDATE.APP from update_sd_preload folder FLASH FILE 7: Special downgrade file in *.skf format for your phone. File 7 and test point you will find on bootloader.com /free section. Good luck! BR! |
The Following User Says Thank You to george gsm For This Useful Post: |
05-31-2020, 09:59 | #11 (permalink) |
Insane Poster Join Date: Jul 2006 Location: Romania
Member: 311520 Status: Offline Thanks Meter: 6 | Huawei Mate 20 Lite (SNE-LX1) dead boot due to downgrade firmware.. only test point he sees it..phones detected as "HUAWEI USB COM 1.0". I need a file to repair!! |
05-31-2020, 10:08 | #12 (permalink) |
Member: 311520 Status: Offline Thanks Meter: 6 | Hello team Sigma! Huawei Mate 20 Lite (SNE-LX1) dead boot due to downgrade firmware.. only test point he sees it..phones detected as "HUAWEI USB COM 1.0". I need a file to repair!! I want dead boot repair of this devices. please nice if you can! |
06-01-2020, 08:05 | #13 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | See these manuals: Flashing / Downgrading using full OTA UPDATE files FACTORY MODE: phones detected as "HUAWEI USB COM 1.0" You can use original Huawei flash files. |
