08-30-2016, 05:20 | #1 (permalink) |
Junior Member Join Date: Jul 2008
Member: 822148 Status: Offline Thanks Meter: 1 | Unlock p8lite huawei ALE-L21 problem [solved] SigmaKey 2.19.00 HiSi: Direct unlock Connecting.... USB Serial Device (COM41), Provider: Microsoft, Driver ver.: 10.0.14393.0, Date: 6/21/2006, USB\VID_12D1&PID_105C&REV_9999&MI_02 Firmware: ALE-L21 C02B589CUSTC02D001, Date: Thu Jun 16 22:22:25 CST 2016, Provider: vodafone/uk Boot Version: DailyBuild_201606162215_BOOT, FastBoot Version: DailyBuild_201606162215_FASTBOOT Recovery Version: (unknow), System Version: ALE-L21C02B589_SYSTEM Removing firmware protection.................................Unable to connect to the server. Please check your network. Removing firmware protection...^ ADB Device Preparing...Please ROOT the phone first! How to unlock it ?? Br Obeone13 Last edited by Gsmserver; 10-10-2016 at 13:10. |
09-05-2016, 13:22 | #3 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Budapest
Member: 472482 Status: Offline Thanks Meter: 105 | I have also this problem, is hi silicon phone and not need root Turn the phone ON and wait until it fully starts up Set the phone into the Manufacture Mode by entering *#*#2846579#*#* code (follow the instruction from the Enable Manufacture Mode manual) Connect the phone to PC using USB cable Install phone drivers (only if the phone is connected for the first time). Select "HISILICON" platform from the tab menu in the upper left side of the software Wait for 10 seconds Go to "Unlock" tab Select "Android Adapter PCUI". If there is no such port, select "Comneon Mobile High-speed Modem" Press "Unlock" button The message "Unlock done… OK" indicates that procedure has been completed successfully Disconnect the handset A phone is unlocked Can give the solution to unlock it this phone ? Thanks |
