10-28-2014, 14:03 | #1 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1594731 Status: Offline Thanks Meter: 8 | vodafone 889n 4.4.2 unlocked i have unlocked several pieces of this model, but this one is android 4.4.2 and i think it is not supported. i had to root with other tool, sigma could not root, but still unlock fails i also followed the steps for this model in website and in following link http://forum.gsmhosting.com/vbb/f719...error-1873183/ but by disabling MTP the phone com port does not show up in the list. I have to re-enable USB debugging mode from developer options, then I can start the process SigmaKey v.2.06.03 419253298 Sigma dongle 2.06, Initializing...OK Pack 1: Not activated --- 2014-10-28 13:33:12 --- SigmaKey 2.06.03 ADB: Obtain root privileges (autodetect) * daemon not running. starting it now * * daemon started successfully * ^ ROMaster Composite ADB Interface Version: Linux version 3.4.0-g9b6969a-00565-g104f241 (mine@mine-virtual-machine) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu May 22 03:49:12 CST 2014 Phone model: Vodafone Vodafone Smart 4 turbo Firmware: KVT49L Date: Thu May 22 03:08:58 CST 2014 Android Version: 4.4.2 "KitKat" Obtaining root privileges...Unfortunately, heuristic method have been failed. SigmaKey 2.06.03 ADB: Direct unlock * daemon not running. starting it now * * daemon started successfully * ^ ROMaster Composite ADB Interface Version: Linux version 3.4.0-g9b6969a-00565-g104f241 (mine@mine-virtual-machine) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu May 22 03:49:12 CST 2014 Phone model: Vodafone Vodafone Smart 4 turbo Firmware: KVT49L Date: Thu May 22 03:08:58 CST 2014 Baseband Processor: Qualcomm MSM8926 Reading security block...Not found Last edited by GSM_Support; 12-23-2014 at 13:02. |
10-28-2014, 14:21 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ rajum1, please check this 2 manuals. Enable diagnostic port
Video tutorial: Best Regards GSMServer team Last edited by GSM_Support; 11-03-2014 at 11:09. |
The Following User Says Thank You to GSM_Support For This Useful Post: |
10-28-2014, 17:18 | #4 (permalink) |
Member: 1594731 Status: Offline Thanks Meter: 8 | hello and thank you for reply, however your suggestiones have not solved the issue 1. i have already enabled diag port 2. by disabling MTP the port is gone, I have to reenable usb debugging. 3. the name of the port/driver is ^ ROMaster Composite ADB Interface, does this have anything to do with the issue? 4. i have re rooted the phone with vroot, but still the same any more suggestions? |
10-29-2014, 09:02 | #5 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | You have to unlock this phone via Android Diagnostics USB VCOM. It has to appear after enabling it in Sigma sw. Restart this phone, install all needed drivers and try once again. http://forum.gsmhosting.com/vbb/f719...ocked-1869340/ |
10-29-2014, 11:11 | #6 (permalink) |
Crazy Poster Join Date: Aug 2010 Location: Spain
Member: 1358544 Status: Offline Thanks Meter: 12 | 1.- FAIL Code: SigmaKey 2.06.03 ADB: Direct unlock Version: Linux version 3.4.0-g9b6969a-00606-gf63fe7e (mine@ubuntu) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Tue Jul 15 11:11:32 CST 2014 Phone model: Vodafone Vodafone Smart 4 Firmware: KVT49L Date: Tue Jul 15 10:32:21 CST 2014 Baseband Processor: Qualcomm MSM8210 [B]Reading security block...Not found[/B] ----------------------------------------------------------------------- run: adb shell Code: su setprop sys.usb.config diag,adb Unlock via qcom tab , direct unlock Code: SigmaKey 2.06.03 Qcom: Direct unlock Coolpad Android Diagnostics USB VCOM (COM370), Provider: Coolpad Incorporated, Driver ver.: 2.0.9.6, Date: 28/05/2012, USB\Vid_1ebf&Pid_70f8&Rev_0228&MI_00 Firmware: GW_T3_180338_03 Date: Jun 10 2014 11:08:16, Apr 14 2014 00:00:00, BAAAANWZ IMEI: 35xxxxxxxxxxxxxxxxxx Bluetooth address: 000000000000 Security area saved to "C:\Documents and Settings\Rober\Mis documentos\SigmaKey\security backup\35xxxxxxxxxx_.skb" Unlocking phone...Done Restarting phone....PLEASE RESET PHONE MANUALLY! |
The Following User Says Thank You to robergc For This Useful Post: |
10-29-2014, 11:15 | #7 (permalink) | |
Member: 239548 Status: Offline Thanks Meter: 2,781 | robergc, Quote:
The Following User Says Thank You to mcandre For This Useful Post: |
11-04-2014, 13:22 | #8 (permalink) |
No Life Poster Join Date: Feb 2004
Member: 52597 Status: Offline Thanks Meter: 275 | Code: 62xxxxxxx Sigma dongle 2.06, Initializing...OK Pack 1: Activated --- 2014-11-04 12:59:48 --- SigmaKey 2.06.04 ADB: Direct unlock * daemon not running. starting it now * * daemon started successfully * ^ ROMaster Composite ADB Interface Version: Linux version 3.4.0-g9b6969a-00565-g104f241 (mine@mine-virtual-machine) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu May 22 03:49:12 CST 2014 Phone model: Vodafone Vodafone Smart 4 turbo Firmware: KVT49L Date: Thu May 22 03:08:58 CST 2014 Version: 4.4.255.04.T3.140522.KVT49L.VF.ES Baseband Processor: Qualcomm MSM8926 Version: 4.4.255.04.T3.140522.KVT49L.VF.ES Reading security block...Not found --- 2014-11-04 13:14:26 --- SigmaKey 2.06.04 Qcom: Direct unlock Coolpad Android Diagnostics USB VCOM (COM580), Provider: Coolpad Incorporated, Driver ver.: 2.0.9.6, Date: 5/28/2012, USB\VID_1EBF&PID_70F8&REV_0228&MI_00 Firmware: GWL_T3_1013901_01 Date: May 19 2014 17:05:18, Apr 21 2014 06:00:00, DAAAANAZ IMEI: 353853060xxxxxxx Bluetooth address: 000000000000 Security area saved to "C:\Users\iserv\Documents\SigmaKey\security backup\353853060xxxxxx_.skb" Unlocking phone...Done Restarting phone....PLEASE RESET PHONE MANUALLY! Done After enabling diag port all ok |
The Following User Says Thank You to silhouette For This Useful Post: |
01-14-2015, 09:51 | #9 (permalink) |
No Life Poster Join Date: Sep 2008 Location: with mobile phone Age: 35
Member: 866865 Status: Offline Sonork: 1645198 Thanks Meter: 182 | Thanks mastar --------- 2015-01-14 14:03:13 --------- SigmaKey 2.07.04 ADB: Enable diagnostic port * daemon not running. starting it now * * daemon started successfully * ^ Android Composite ADB Interface Version: Linux version 3.4.0-g9b6969a-00565-g104f241 (mine@mine-virtual-machine) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu May 22 08:19:45 CST 2014 Phone model: Vodafone Vodafone Smart 4 turbo Firmware: KVT49L Date: Thu May 22 07:37:59 CST 2014 Version: 4.4.255.04.T3.140522.KVT49L.VF.IE Baseband Processor: Qualcomm MSM8926 Preparing...Done --------- 2015-01-14 14:09:36 --------- SigmaKey 2.07.04 Qcom: Direct unlock User interface have been changed. Now use "Android ADB" bookmark (top-left corner) to proceed. --------- 2015-01-14 14:16:50 --------- SigmaKey 2.07.04 Qcom: Direct unlock User interface have been changed. Now use "Android ADB" bookmark (top-left corner) to proceed. --------- 2015-01-14 14:17:14 --------- SigmaKey 2.07.04 ADB: Direct unlock * daemon not running. starting it now * * daemon started successfully * ^ Coolpad Android Composite ADB Interface Version: Linux version 3.4.0-g9b6969a-00565-g104f241 (mine@mine-virtual-machine) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu May 22 08:19:45 CST 2014 Phone model: Vodafone Vodafone Smart 4 turbo Firmware: KVT49L Date: Thu May 22 07:37:59 CST 2014 Version: 4.4.255.04.T3.140522.KVT49L.VF.IE Baseband Processor: Qualcomm MSM8926 Version: 4.4.255.04.T3.140522.KVT49L.VF.IE Reading security block...Not found --------- 2015-01-14 14:19:47 --------- SigmaKey 2.07.04 ADB: Enable diagnostic port * daemon not running. starting it now * * daemon started successfully * ^ Coolpad Android Composite ADB Interface Version: Linux version 3.4.0-g9b6969a-00565-g104f241 (mine@mine-virtual-machine) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu May 22 08:19:45 CST 2014 Phone model: Vodafone Vodafone Smart 4 turbo Firmware: KVT49L Date: Thu May 22 07:37:59 CST 2014 Version: 4.4.255.04.T3.140522.KVT49L.VF.IE Baseband Processor: Qualcomm MSM8926 Preparing...Done --------- 2015-01-14 14:20:40 --------- SigmaKey 2.07.04 Qcom: Direct unlock Coolpad Android Diagnostics USB VCOM (COM126), Provider: Coolpad Incorporated, Driver ver.: 2.0.9.6, Date: 5/28/2012, USB\Vid_1ebf&Pid_70f8&Rev_0228&MI_00 Firmware: GWL_T3_1013901_01 Date: May 19 2014 17:05:18, Apr 21 2014 06:00:00, DAAAANAZ IMEI: 353853060963530 Bluetooth address: 000000000000 Security area saved to "C:\Documents and Settings\Extreme Solution\My Documents\SigmaKey\security backup\353853060963530_.skb" Unlocking phone...Done Restarting phone....PLEASE RESET PHONE MANUALLY! Done worked for me |
01-29-2015, 16:13 | #10 (permalink) |
Freak Poster Join Date: Jul 2002 Location: Europe Age: 47
Member: 13827 Status: Offline Thanks Meter: 16 | Cant unlock this phone I activated pack 1 In SIGMA software "ENABLE DIAGNOSTIC PORT" is not active in Device manager is "ANDROID" yellow caution...what driver to choose automaticaly manualy not any driver suite. I try win XP try WIN 7 no luck. What the hell that phone is ??? |
01-29-2015, 16:29 | #12 (permalink) |
Member: 13827 Status: Offline Thanks Meter: 16 | Alcatel Android Smartphones - Sigma - MTK, Qualcomm, Broadcom, TI OMAP based flashing, unlocking, repair IMEI solution drivers from file coolpad.rar not work ... |
01-29-2015, 16:40 | #14 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ tgsm, As it was earlier mentioned by mcandre, it looks like unlock operation is getting performed improper, that's why such an issues appears. Please double check carefully unlock manual, ensure that you have enabled usb debugging and activated diag port and run operation as it is signed in the manual. Best Regards GSMServer team |
