02-10-2013, 08:28 | #1 (permalink) |
Insane Poster Join Date: Feb 2013 Location: Philippines
Member: 1881815 Status: Offline Thanks Meter: 9 | my chinaking got problem (ANSWERED) pin finder and auto detect dont work...the only thing that work is that its rj45 port and supplied by battery because its vcc pin also has low current.... i hope comments from product supporter... Last edited by cellcare prasad; 02-12-2013 at 11:28. |
02-10-2013, 09:58 | #4 (permalink) |
Member: 1881815 Status: Offline Thanks Meter: 9 | sir,even i put proper connection of vcc and ground,it always goes like this...but if i change with cellphone battery,sometimes it connect sometimes did not...but it only work sometimes on mtk mobile phone... |
The Following User Says Thank You to microtech1988 For This Useful Post: |
02-10-2013, 14:36 | #5 (permalink) |
Product Supporter Join Date: Mar 2011 Location: ..::INDIA::.. Andhra Pradesh Age: 41
Member: 1528548 Status: Offline Sonork: 100.1613286(Offline) Thanks Meter: 2,244 | change main cable I think your black and red clips not working post result |
The Following User Says Thank You to ..:: SONY ::.. For This Useful Post: |
02-10-2013, 15:20 | #6 (permalink) | |
No Life Poster Join Date: Sep 2010 Location: philippines
Member: 1388679 Status: Offline Sonork: 1597516:GsmSolution Thanks Meter: 2,757 | Quote:
check main cable if it can power on phone.connect positive & negative to phone then try to power on phone.if not try with other cable BR | |
The Following User Says Thank You to GsmSolution. For This Useful Post: |
02-11-2013, 01:11 | #7 (permalink) |
Member: 1881815 Status: Offline Thanks Meter: 9 | power cable cannot power on phone...then i try to test its voltage by clipping two clip into test probe of multitester then i found out that its voltage is not stable..the tester goes like this,forward and a second it open then deflect then open and so on..i try cable of avator to test its voltge supply,result,the same problem...now the box cant found D+ and D- even i use new mobile to test and also using battery as ppppppower supply... |
02-11-2013, 07:31 | #9 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: VIZAG,A.P, INDIA
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | Quote:
YOUR BOX IS OK | |
The Following User Says Thank You to cellcare prasad For This Useful Post: |
02-12-2013, 06:37 | #10 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | no sir this is not cable problem. i m try to change cable. but not success. |
The Following User Says Thank You to debmobile For This Useful Post: |
02-12-2013, 07:08 | #12 (permalink) |
Junior Member Join Date: Dec 2012 Location: Burot,Allacapan,Cagayan
Member: 1856095 Status: Offline Sonork: rj_15_luv Thanks Meter: 4 | try to re install the drivers of your china king box sir... |
The Following User Says Thank You to rj_15_luv For This Useful Post: |
02-14-2013, 08:50 | #13 (permalink) |
Member: 1881815 Status: Offline Thanks Meter: 9 | thanks everyone for sharing their comments and suggestion...today i test again the box,thanks to *** it working fine...i dont know if what is the reason of malfunction like hardware or software.i've just set aside it for two days....because i have nothing to do,i test it again..thanks a lot gsmhosting family... |
