11-10-2015, 13:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | After Format Encryption Unsuccessful Hot World,s 1st Solution By Merapi Team ONCE AGAIN AS USUAL MERAPI TEAM PRESENTING HOT WORL,S TOP SOLUTION OF ( Encryption Unsuccessful ) AFTER FORMAT ON ANY TOOL STEP 1 READ BIN FILE FROM FAULTY PHONE STEP 2 MAKE SCATTER BY MERAPI STEP 3 DELETE DATA AND CACHE OR ONLY DATA FROM ORIGINAL SCATTER FILE STEP 4 SEARCH ANY ANOTHER DATA FILE WITH SAME CPU MODEL NAME DOESNT MATTER COPY AND PASTE IN SCATTER FILE WHICH YOU READ FROM FAULTY PHONE HERE ORIGINAL MODEL IS SAM3812 DATA IS COPIED FROM SAM7562 BOTH ARE MTK 6572 EMMC STEP 5 WRITE THAT SCATTER FILE BY MERAPI AND ALL DONE ENJOY THE REAL FUN WITH MERAPI TOOL KEEP INTOUCH WITH US FOR MORE HOT SOLUTIONS |
The Following 25 Users Say Thank You to amn32 For This Useful Post: |
11-25-2015, 09:45 | #4 (permalink) | |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Quote:
Also note dont use userdata that has large size ok..use userdata size that has small size of same cpu and values ok... | |
11-27-2015, 20:32 | #7 (permalink) | |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Quote:
One more thing this solution can help if phone is on logo after format too. | |
The Following 2 Users Say Thank You to amn32 For This Useful Post: |
12-01-2015, 08:41 | #9 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: west java
Member: 756701 Status: Offline Sonork: 100.1592286 Thanks Meter: 91 | Not work to mtk 6589 >>> advan S5d encryption unsuccessful log read info Quote:
BR | |
12-01-2015, 08:59 | #10 (permalink) | |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Quote:
Take BIN backup from this phone with MERAPI tool>>>>>Split into SCATTER>>>>Took out USERDATA and CHACHE file from scatter backup into other folder and keep safe>>>>>>Replace other USERDATA and CHAHE file into scatter folder from same MT6583/89 backup>>>>>Finally write modified scatter into phone with only CHAHE and USERDATA file. BR. FeeFi | |
12-01-2015, 09:57 | #11 (permalink) | |
Member: 756701 Status: Offline Sonork: 100.1592286 Thanks Meter: 91 | Quote:
BR | |
12-05-2015, 14:46 | #12 (permalink) |
Major Poster Join Date: Mar 2008 Location: indonesia
Member: 716073 Status: Offline Thanks Meter: 17 | 1. if you erase it then your phone die, you can flash it by changing userdata 2. but if you erase it then your phone still alive, you'll need to change emmc br |
The Following User Says Thank You to mawan161080 For This Useful Post: |
01-10-2016, 18:14 | #15 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | helo boss,,,it will for those phones ,,that were preloader damage,,so,,so,,plz inform,,what about these phone,,that have preloader ,or bootloader damage,,mtk 6572 ,nand if erased,,, what is the real solution,,,plz inform,, solution with mirapi TOOLL,,,,THANKS |
