All success stories Volcano BOX with Huawei, ZTE , Vodafone ,and other Phone Huawei G6005 http://www.euqueroumhuawei.com.br/Ap...ages/g6005.jpg 100% Sucess VolcanoBox http://www.gsm-hosting.com.br/Luisin...ages/g6005.png Firmware G6005 Here LuisinhoCell |
good test report bro pls post in sucess/stories/thread also bro wbr |
thanks for test report. br;) |
LG X335 Supported Read Info, Read Flash, Format, Write Imei and other http://www.gsm-hosting.com.br/Luisin...x335volcan.png Code: Connecting... |
ZTE X760 http://blog.phoneslimited.co.uk/file...0-black-pl.jpg http://www.gsm-hosting.com.br/Luisin...mages/x760.png Read Info Code: Detection initiated, connect the phone and power on it... Code: Vcc: null Code: Vcc: null |
Alcatel One Touch 678G http://img.baratomania.com.br/loja/i...19/37723_1.jpg http://www.gsm-hosting.com.br/Luisin...alcatelone.png Read Info Code: Gnd: 7 8 Code: Detection initiated... |
ZTE N290 http://www.gizmodo.com.br/sites/all/...16/zten290.jpg http://www.gsm-hosting.com.br/Luisin...s/zten2900.png Format Code: Detection initiated, connect the phone and power on it... Code: Detection initiated, connect the phone and power on it... Code: Vcc: null Code: Detection initiated, connect the phone and power on it... |
Huawei G6600 http://telemoveisbaratos.org/wp-cont...awei-g6600.jpg http://www.gsm-hosting.com.br/Luisin...huaweig660.png Read Info Code: Vcc: null Code: Vcc: null Code: Vcc: null |
Huawei 6620S http://www.cissamagazine.com.br/ecom...32361677_1.jpg Read Info Code: Vcc: null Code: Gnd: 5 Code: Analyzing Rx and Tx... |
Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=921600 Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=9 TXD=21 Connecting... Connected...sending boot... Failed to run bootloader... +++++++++++++++++++End at: 4/24/2012 1:11:33 PM+++++++++++++++++++ -------------------Created: 4/24/2012 1:11:40 PM------------------- Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=115200 Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=9 TXD=21 Connecting... Connected...sending boot... Failed to run bootloader... +++++++++++++++++++End at: 4/24/2012 1:11:47 PM+++++++++++++++++++ -------------------Created: 4/24/2012 1:12:08 PM------------------- Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=115200 Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=9 TXD=21 Connecting... Connected...sending boot... Failed to run bootloader... +++++++++++++++++++End at: 4/24/2012 1:12:14 PM+++++++++++++++++++ -------------------Created: 4/24/2012 1:12:28 PM------------------- Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=115200 Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=9 TXD=21 Connecting... Connected...sending boot... Failed to run bootloader... +++++++++++++++++++End at: 4/24/2012 1:12:34 PM+++++++++++++++++++ -------------------Created: 4/24/2012 2:02:06 PM------------------- Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=Auto-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=921600 Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=9 TXD=21 Connecting... Connected...sending boot... Failed to run bootloader... +++++++++++++++++++End at: 4/24/2012 2:02:13 PM+++++++++++++++++++ -------------------Created: 4/24/2012 2:02:22 PM------------------- Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=9 TXD=21 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000EA6A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Failed to set Flash parameters... +++++++++++++++++++End at: 4/24/2012 2:02:36 PM+++++++++++++++++++ -------------------Created: 4/24/2012 2:02:56 PM------------------- Chip=SpreadTrum Action=Format FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=9 TXD=21 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000EA6A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Failed to set Flash parameters... +++++++++++++++++++End at: 4/24/2012 2:03:10 PM+++++++++++++++++++ -------------------Created: 4/24/2012 2:03:18 PM------------------- Chip=SpreadTrum Action=Format FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=9 TXD=21 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000EA6A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Failed to set Flash parameters... +++++++++++++++++++End at: 4/24/2012 2:03:32 PM+++++++++++++++++++ -------------------Created: 4/24/2012 2:04:12 PM------------------- Chip=SpreadTrum Action=Format FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=115200 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=9 TXD=21 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000EA6A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x003B0000, Size=0x00050000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. +++++++++++++++++++End at: 4/24/2012 2:04:39 PM+++++++++++++++++++ -------------------Created: 4/24/2012 2:06:54 PM------------------- Chip=SpreadTrum Action=Reset FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=115200 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=9 TXD=21 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000EA6A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. +++++++++++++++++++End at: 4/24/2012 2:07:13 PM+++++++++++++++++++ -------------------Created: 4/24/2012 2:26:36 PM------------------- Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=115200 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=9 TXD=21 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000EA6A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=352396060020209 IMEI 2=910575601400468 ------Auto Format Address------- Start=0x003B0000 Size =0x00050000 Read FS info...done +++++++++++++++++++End at: 4/24/2012 2:26:56 PM+++++++++++++++++++ -------------------Created: 4/26/2012 1:58:03 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=115200 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF004000150000 NOR_Size=0MB NOR_Name=Unsupport Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000150000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... ProjectID Not Found. +++++++++++++++++++End at: 4/26/2012 1:58:15 PM+++++++++++++++++++ -------------------Created: 4/26/2012 2:00:13 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=InternalRamBoot Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF004000150000 NOR_Size=2MB NOR_Name=SF_W25Q16CV NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6252 Flash: SF_W25Q16CV setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok +++++++++++++++++++End at: 4/26/2012 2:00:20 PM+++++++++++++++++++ -------------------Created: 4/26/2012 2:00:31 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=921600 CPU_Type=MT6252 CPU_ID=00000007 NOR_ID=00EF004000150000 NOR_Size=0MB NOR_Name=Unsupport Flash NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000150000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... ProjectID Not Found. +++++++++++++++++++End at: 4/26/2012 2:00:43 PM+++++++++++++++++++ -------------------Created: 4/26/2012 2:17:59 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=921600 Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=21 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. User abort, freeing Download Agent, please wait... +++++++++++++++++++End at: 4/26/2012 2:18:07 PM+++++++++++++++++++ Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=21 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. User abort, freeing Download Agent, please wait... The process stopped. +++++++++++++++++++End at: 4/26/2012 2:18:08 PM+++++++++++++++++++ -------------------Created: 4/26/2012 2:18:20 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver3.848 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=921600 CPU_Type=MT6253 CPU_ID=0000000F NOR_ID=0089890300000000 NOR_Size=16MB NOR_Name=[INTEL] PF38F30xxM0x1xx NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=21 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0089890300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D35_GFIVE_IT64H_CIF_V05 +++++++++++++++++++End at: 4/26/2012 2:19:05 PM+++++++++++++++++++ -------------------Created: 4/26/2012 2:19:16 PM------------------- Chip=MTK Action=Format FlashType=NOR boot=Ver3.848 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=921600 Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=21 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. User abort, freeing Download Agent, please wait... +++++++++++++++++++End at: 4/26/2012 2:19:48 PM+++++++++++++++++++ Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=21 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. User abort, freeing Download Agent, please wait... The process stopped. +++++++++++++++++++End at: 4/26/2012 2:19:49 PM+++++++++++++++++++ -------------------Created: 4/26/2012 2:19:57 PM------------------- Chip=MTK Action=Format FlashType=NOR boot=Ver3.848 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=115200 CPU_Type=MT6253 CPU_ID=0000000F NOR_ID=0089890300000000 NOR_Size=16MB NOR_Name=[INTEL] PF38F30xxM0x1xx NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=21 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0089890300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: D35_GFIVE_IT64H_CIF_V05 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done +++++++++++++++++++End at: 4/26/2012 2:20:50 PM+++++++++++++++++++ -------------------Created: 4/26/2012 2:21:22 PM------------------- Chip=MTK Action=IMEI FlashType=NOR boot=Ver3.848 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM16 Baudrate=115200 Initializing... DA_LIB_VER_4.0.3.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=21 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=358688000000158 IMEI=358688000000158 Rebulid IMEI1=353056241231327 Rebulid IMEI2=353056413213213 +++++++++++++++++++End at: 4/26/2012 2:22:00 PM+++++++++++++++++++ |
Haier C-3010 CDMA set user code done by VOLCANO http://img337.imageshack.us/img337/2...10usercode.jpg Bro Dipankor-ctg(gsmasha) |
Phone Huawei G6608 http://imagens.extra.com.br/Control/...rquivo=4478248 Read Info Code: Detection initiated, connect the phone and power on it... Code: Detection initiated, connect the phone and power on it... Code: Detection initiated, connect the phone and power on it... LuisinhoCell |
