01-20-2013, 11:17 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: .::Rawalpindi::.
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | Box openning error |
01-21-2013, 09:41 | #2 (permalink) |
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | no one here faced this problem??? anyway i solved this but have another issue now... that is when my network connection is enabled volcano tool not open.. and when i open the soft after disable my newrork connection it opens and works fine.. |
01-21-2013, 09:44 | #3 (permalink) |
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | there is some problem in volcano that tool tries to connect to internet when we open it... as i am using a connection that is besed on mikrotik winbox so ip changes time by time so tool opens and closed by itself... |
01-21-2013, 18:16 | #6 (permalink) |
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | i already did... but as i told you problem is because of mikrotik winbox connection. i want to know that is this possible to disable server news in tool? i think it will solve my problem. as i can use volcano without any problem when i open it after disabling network connection (i disable network only for opening tool after it is open i can enable it and use net also) |
01-21-2013, 19:01 | #7 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000. | |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
